transmission shifting - TCCoA Forums
post #1 of 5 (permalink) Old 07-12-2019, 06:20 PM Thread Starter
Mr.Thunderbird's Avatar
I had the trans rebuilt a couple of years ago. Shifts are very quick and firm but not banging into gear. Lately when I do a near or wide open run I'm hearing a squealing on the 2/3 shift. Not tires I'm pretty sure. Do clutches or bands slip and would you here that??? Thanks
Mr.Thunderbird
Mr.Thunderbird is offline
post #2 of 5 (permalink) Old 07-12-2019, 08:22 PM
It’s most likely the serpentine belt.
post #3 of 5 (permalink) Old 07-13-2019, 06:31 AM
Did you Jmod the valve body & accumulator springs at the time of the rebuild, before the rebuild or since the rebuild? My guess, based on your description, is that you did not.
I'd get that done if you really want banging into gear shifts. Any questions about it just let us know.
post #4 of 5 (permalink) Old 07-13-2019, 10:24 AM
This
post #5 of 5 (permalink) Old 07-13-2019, 10:45 AM
Lazarus' tranny squeaks a bit going into 2nd and 3rd; as the TC is locked as soon as it exits 1st.
Don't ever do a wot into 4th; that's a sure way to kill a tranny.
It sounds like a dry bolt getting ready to snap; only louder.
It's a hardware fail in my case, IMHO; that tranny's always done it. It's not the VB, I changed it. It's a shaft seal fail somewhere, or a leak in the case.
I think one good wot 2-3 shift will leave pieces laying in the road.
I hope it's your Serp Belt, OP.
I'm waiting to replace this one with one I have in the garage, when it finally dies.
If I can, I want to see why it does that, but I doubt it will be intact enough to autopsy.
Similar Threads
Transmission shifting hard or not wanting to shift barnsworth 4R70W Transmissions 10 03-30-2019 05:55 PM
97 Cougar Transmission shifting problem fixed fourpointsix 4R70W Transmissions 8 01-27-2013 04:07 PM
transmission not shifting? CoolCat27 4R70W Transmissions 8 11-07-2010 07:37 PM
Transmission shifting scbeast89 4R70W Transmissions 4 05-11-2009 12:22 PM
transmission/shifting question. 95T-BirdInAz Drive Train 1 10-04-2005 08:33 AM
