So, I'm beginning to lose a little patience with my 'bird...
I'm in the process of having it tuned by Don, and am now at the point that it needs loaded tests (after dealing with a bank-to-bank fueling disagreement issue). I've only got until October to get this car completely dialed-in before time is up.
Problem is, I'm now on my 2nd MLPS with my 2nd round of P0707 (circuit A low voltage) throwing a wrench in the whole plan.
Was driving the car fine few weeks ago, then got hit with the first P0707. Symptom was blinking OD light and car would drop 3rd / limp home mode.
Replaced that MLPS, problem disappeared until yesterday when the P0707 showed up again and this time, while driving home from work today, car dropped 3rd briefly then reverted to full limp-home mode with only 2nd gear active. Total time between sensors was about two weeks.
Does this sound like a bad MLPS again, or do I need to look elsewhere? It's the Standard Motor Products part# NS95, exact same one AZ and Oh-Really sells. What are the chances they're getting cooked from the long-tubes?
