Did you damage your 4R70W with J-Mod - TCCoA Forums
View Poll Results: Did you damage your 4R70W by performing J-Mod?
Yes 6 7.41%
No 72 88.89%
Yes, but I fixed it easily/cheaply/quickly 3 3.70%
Voters: 81. You may not vote on this poll
post #1 of 30 (permalink) Old 10-17-2003, 12:27 AM Thread Starter
Send a message via AIM to willum
How many people have performed the J-Mod to the transmission and had a problem that was a result of the mod, or your own handi-work while performing it.
I'm looking into performing this and it scares the bejebus out of me. I'm sure that I can do it but I gotta get up the nerve to do so, not to mention the inch-lb torque wrench and parts.
Willum
willum is offline
post #2 of 30 (permalink) Old 10-17-2003, 02:21 AM
I didn't damage it, but it sure as hell didn't shift into drive after we bolted it back up. The gear selector didn't shift into drive, (luckily I could get out of the driveway in reverse, then back into it again in reverse.) The rod that slides in the VB was sticking and we had to tweak it back so it could slide freely.
What I did was make a folder on my laptop with every bit of info I could gather. I studied it for about a week. Just have the printouts or files handy, just in case. It's really simple once you get in their, I could do it all over again with no documents.
Get the Jmod article off tccoa, check mn12performance.com for all their trans info, and use the search here, you'll have all the info you ever need.
RyanG is offline
post #3 of 30 (permalink) Old 10-17-2003, 08:00 AM
I didn't have any problems at all, just go slow and read the article about 10 times before you start, and then another 10 while you are doing it
Rich95XR7 is offline
post #4 of 30 (permalink) Old 10-17-2003, 10:52 AM
Trumpeter Extraordinaire
IronChopz's Avatar
I'm not technically-oriented when it comes to cars, so I spent about a year deliberating whether or not to do it. When my car-repair-savvy brother visited in August, I asked him if he thought he could do it. He leafed through the article, and after 10 minutes, he said "Let's get to it!"
It helps to have a helper who knows what to look for. I was amazed at how smoothly everything went, and equally surprised that it took less than 4 hours. No problems encountered.....an a big thanks to my brother!
Just like Rich95XR7 states: read the article several times, and keep it handy while you do the work.
IronChopz is offline
post #5 of 30 (permalink) Old 10-17-2003, 11:47 AM
No problems at all, but I REALLY took my time, since I was doing it by myself and this was my first time in an automatic transmission. I even did the reverse and OD servos, which seem to cause the most problems for people. Read the directions as many times as it takes, start early in the day (in case you need to make a parts run), and don't get in a hurry.
Marcus
Marcus is offline
post #6 of 30 (permalink) Old 10-17-2003, 08:18 PM
Silver95Bird's Avatar
I've done 4 of these things already, my last one took 2 hours I think ... LOL. If you're a first-timer, I'd say skip the OD and reverse servos - they're optional anyway. Take your time, read the directions and Don't rush! Rushing is how you make mistakes. Trust me. I've messed up putting the OD servo back in just like so many others have. Not that it's a big deal, but you don't want to have to drop the pan again.
Silver95Bird is offline
post #7 of 30 (permalink) Old 10-18-2003, 10:40 AM
ummm fubar can we say radiator?
1996 Thunderbird 4.6 -Sold-
Bunch of motorcycles
2004 F150
KrAzyT is offline
post #8 of 30 (permalink) Old 10-21-2003, 10:56 PM
terraplane8's Avatar
I feel like I'm going to confession here...
My failure is not related to the mod itself, just my own stupidity.
I decided to do mine at 107,000 miles. I had already done it on my 94 Mustang AOD-E 2 years ago, and was pleased with the results, so I was ready to kill the bird finally. I screwed mine up because I was stupid. I didn't put enough Mercon V in when I finished it, tried to test drive it, and fried the forward clutches due to lack of line pressure.
My mistake happened because I had recently done the converter and pan drain/refill, and I wasn't going to drain the converter again. Since I dropped the pan and valve body ONLY, I ASSUMED that I only needed about 5-6 quarts to refill it (didn't want to overfill). I also assumed it would need to cycle around a bit to fill all the passages in the valve body, and that was why the car wouldn't go into gear immediately. Suffice to say, I was wrong... Apparently, the valve body contains a check valve that keeps the converter from draining, and when I pulled the VB, I lost at least half of my converter fluid. I put about 2 miles on it, with it about 4 quarts low. I filled it to the top of the rang, put around 70 miles on it over the next 2 days, and then it lost forward gears when my wife was driving it (of course). She limped it home for 15 miles, not sure how.
Now I have a Dennis Reinhart tranny in mine. I'm very happy, to say the least...
But with labor for the install ($585), new radiator ($160) and B&M cooler ($60), and $1600 to Dennis, it was a costly mistake. So much for my tax return and the tiny profit I made from selling my house...
Again, my failure is not related to the mod itself, just my own stupidity.
Submariners do it deeper...
terraplane8 is offline
post #9 of 30 (permalink) Old 10-23-2003, 11:15 PM
Aaron_T's Avatar
Who would do something like that?
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Scotts' custom gauges
Aaron_T is offline
post #10 of 30 (permalink) Old 10-26-2003, 03:30 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
my friend joe helped me do it. he did his own car before we did mine so he had some experience. it took us about 3 hours to do the jmod and install a cooler. we had all the neccessary tools and parts so we didnt have to make any runs to the store. everything went as smooth as possible.
Frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #11 of 30 (permalink) Old 10-26-2003, 11:52 PM
Aaron_T's Avatar
I figure I should say I wasn't making fun of you Terraplane8.
I did the exact same thing (costed about $300 less) to my 97' in the middle of last winter which is why I put the 'big grin'.
3 hours seems like it went very well. It def. took me a lot longer.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #12 of 30 (permalink) Old 10-28-2003, 10:11 PM
Yes, AaronT, I remember you and I going in circles trying to figure ours out last Spring... Same symptoms for you, I believe(?).
Anyway, I finally got my DennisR tranny installed a month ago (I had a busy Summer with a lot of travel for work). I'm pretty happy with it, although I think I need a new tranny mount now. Shifts are way better than before, but it kinda clunks a bit going into second, and has some underbody vibrations when slowing down from hiway speeds; feels like a driveline/bushing-thing, maybe the 3rd member bushings or tranny mount are getting loose on me. Gonna check it over tomorrow when I change the oil.
post #13 of 30 (permalink) Old 04-29-2004, 11:14 PM
Did mine this past winter, while the tranny was in the car of course, and somehow got disorientated right before I pulled the 1-2 accumulator out. Ended up pulling out the OD servo bore, letting the band slip off, not realizing it. Took it out for a drive when I was done and no OD. Figured out that was my problem a day later and then the next day dropped everything out and put it back in. Worked fine ever since. And yeah, I read through the article about 10 times as well. I've helped do 2 others after mine and it never takes very long now. Oh, and that was my first time inside an automobile transmission.
whitecoug is offline
post #14 of 30 (permalink) Old 05-02-2004, 12:11 PM
ITT-BIRD's Avatar
I just did mine too ... as others have mentioned ... i didnt drain the torque convertor also bc its a new one with about 1500 miles on it. BUT i made sure the fluid level was up and kept checking til i had enough in it.
All in all ... the two yrs i spent procrastinating is almost shameful... its alot simpler than you think.
"You Should See the Front!"
1995 Lazer Red Cougar
Custom Tru Duals, PI 4.6, JModded Tranny w/ TC.
Programmed by SCT Xcal2
Thanks to PalmGuy I have this beautiful masterpiece.
ITT-BIRD is offline
post #15 of 30 (permalink) Old 05-06-2004, 10:50 PM
Don't feel bad willum...
I still am contimplating
I want to get my "I KNOW" I can do mods first.. Then to this "dreaded" (scary) mod. I will probably drill the holes for 300+ HP, seeing as I want MAX performance
1997T-Bird is offline
post #16 of 30 (permalink) Old 05-08-2004, 02:41 PM
Lazania's Avatar
If I were you I would buy the PA VB shifts just as good as Jmod VB and is a better VB than stock and is less of a hassle to install than 99+. No Drilling, so know wondering if you did it right ore not, its also a manuel VB. My opinion is you cant beat it for the price and quality.
2011 Mustang GT Premium 6spd
Current Modifications:
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
post #17 of 30 (permalink) Old 05-12-2004, 07:04 AM
PCD
Confirmed V6 Nut
I did my JMod last summer with help from Al Simanek. We went REAL slow and skipped the OD and Reverse servos since I've got a 97.
I'm now ready, except for lack of a torque wrench, to change fluid and filter. Yes, I've put 17,000 miles on the bird already!
My mod came out so well, I let other Bird/Cougar owners drive the car to experience the difference. Thomas was one of my victims, and now Thomas has instituted a JMod tour here in Iowa. 'Nuff said?
PCD is offline
post #18 of 30 (permalink) Old 05-15-2004, 09:13 AM
I'm still contemplating my J-Mod excursion... By reading these articles here, though, it doesn't really seem like it's as bad as I thought it might be. I've never done *any* transmission work, but if I do perform this in the future, I'll have to take a trip to my dad's to have him help me out. He has a massive garage of tools and a decent amount of experience with cars... Not too sure about transmissions, though. Anyone in the northeast Ohio area wanna' come out and help a guy?
95lxv8 is offline
post #19 of 30 (permalink) Old 05-16-2004, 04:15 PM
Aaron_T's Avatar
It's pretty darn easy to do. Just a little messy. You just have to take your time and be careful, really not much to it. A lot of pics floating around here, as well as threads in case you run into trouble.
2000 Summit 700
purgeclip
GMvsFordforum
A.R.T.
Aaron_T is offline
post #20 of 30 (permalink) Old 05-16-2004, 04:19 PM
Yeah, I'm just going to keep on reading posts and looking at pictures until I finally grow bigger balls and just do it someday. Actually, I think I might do it later in the summer. I'm doing all kinds of stuff to my 'Bird to try to give it the best performance without going too crazy with bolt-ons, etc...
95lxv8 is offline
post #21 of 30 (permalink) Old 05-16-2004, 08:09 PM
PCD
Confirmed V6 Nut
Mike,
Why don't you see if the Ohio Chapter of the TCCoA has something link the Iowa Chapter's JMod tour? Nothing else, If you'd like a vacation in Iowa, see what dates Thomas has where.
PCD is offline
post #22 of 30 (permalink) Old 05-17-2004, 06:25 AM
Originally posted by PCD
Mike,
Hahaha! Who takes a vacation to Iowa?? Just playin' - That would be pretty cool if the Ohio Chapter doesn't offer anything like that.
95lxv8 is offline
post #23 of 30 (permalink) Old 05-18-2004, 11:54 PM
The Band, not the Disease!
AnthraxBird's Avatar
OK, well on my 97 4.6.. it had about 60k on it. The install went pretty smooth. I did accidently remove the OD servo, which released the band, causing me too loose 4th gear. I also was torqing the bolts of the valve body, and one of the corner bolts snapped off inside. I just left it. Worked fine. I did go back in and put in a quick drain in the tranny pan. But the Jmod works awesome. Second time I did it was on a friends 94 COugar 4.6... Didn't touch the OD or reverse servo.. just removed the 1-2 and 2-3 springs. All 3 of em. When I was removing the snap ring, I couldnt get the servo out.. i couldnt use a magnet, it was aluminum I think... so I pressed it in and it just went all the way up... I was like What the hell? So I eventually got it out to find out the spring was totally obliterated. Removed all the broken pieces, put the tranny back together, his tranny works perfect to this day. =) I did the later jmod in about 4 hours. All I bought was the 2 plate gaskets, and new tranny oil filter, and new mercron 5. Works perfect.
AnthraxBird is offline
post #24 of 30 (permalink) Old 05-19-2004, 07:31 AM
Geek w/Gearhead Complex
Fubarian's Avatar
oh dear god yes. I still have flashbacks hearing that tinkle of the radiator then of a blowtorch while I'm laying in oil .....
I'll do jmods till the cows come home. Get the parts and give me a place to stay
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
post #25 of 30 (permalink) Old 07-19-2009, 08:31 AM
Old thread I know, but add me to the list of those who killed my tranny with a jmod.........at least I think I killed it, not sure.
I still don't comprehend what happened. It took me almost 6 hours because no matter how simple it was, I double checked, and tripple checked all my work.
I made sure the main control was immaculately clean without removing the valves and springs of course...double checked all the hole locations and sizes, tripple checked I had them labeled correctly, and checked again before drilling them. Made sure all bolts were torqued correctly. I also made sure to verify the checkballs, the black screen, even the "cone" shaped filter was in place.
Put it back together, and it drove fine for 2 days (maybe 20 miles total). Then all of a sudden a shift into 3rd felt like something dragging, or 2 gears enguaged at once fighting each other, and then I smelled that unique smell of clutches, and now I have no 3rd or 4th. I just do not know what went wrong...
-Alan
FirebirdTN is offline
post #26 of 30 (permalink) Old 07-19-2009, 08:44 AM
I did mine the middle of last week and all seems normal (driven about 100 miles so far). However - when I added fluid I think I may have added a bit too much. I just checked the fluid level and it's up to the "H" on "HOT" and the car's been sitting overnight in 70 degree weather. Should I be concerned?
post #27 of 30 (permalink) Old 07-19-2009, 11:59 AM
Holy thread resurection. It's been 5 years.
post #28 of 30 (permalink) Old 07-19-2009, 12:33 PM
If all is good it will not leak down, so it may have problems or overflow when hot.
I'm not sure if it will cause a problem, but I had the same issue and used a long tube and a basting syringe to remove the excess. (from the fill tube)
I'd lower the level; think motor with too much oil; it's hard on the pistons...
(Two quarts of oil over the suggested level in a 2300 engine can pop the top off a piston, fwiw.) That blowd up real nice...
post #29 of 30 (permalink) Old 07-19-2009, 12:38 PM
If I could quantize the amount it's over, I'd say between a quarter and half a quart. If I drained the torque converter a bit (no syringes etc.), wouldn't that end up draining the fluid level?
post #30 of 30 (permalink) Old 07-19-2009, 01:59 PM
CDW6212R's Avatar
Yes, and the dip stick of the trans is not simple to read, level or amounts. A small amount of fluid in a normal level trans can rasie the level on the stick a lot. When it's full there is basically not much air space left in the pan, so it takes very little to get it coming up the dipstick. Drain a little out with what ever method is easier for you to do.
_________
Don
91 Mark VII LSC SE, Griggs and MM suspension soon
98 Mountaineer, A4WD, Big brakes - 12.75" x 1.25" rotors
CDW6212R is offline
