how electronic is the 4R70W? - TCCoA Forums
post #1 of 7 (permalink) Old 12-06-2003, 08:09 AM Thread Starter
5w30 Guzzler
chilipepprflea's Avatar
Send a message via AIM to chilipepprflea
sorry, but i dont--and probably will never--understand how every part of an automatic transmission works.
my question is, when you physically move the shifter from Park to Drive, what is the shifter actually doing? is it doing something physical inside the tranny, or is it just making electrical contacts that cause things to happen like a TV remote?
chilipepprflea is offline
post #2 of 7 (permalink) Old 12-06-2003, 08:35 AM
Refrigerator Raider Hater
GreenBird's Avatar
the shifter moves the manual lever position sensor (MLPS). That tells the EEC what you want to do, and the EEC then tells the trans what to do.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 7 (permalink) Old 12-07-2003, 03:26 PM
3rd Gear Chirper
hotbird's Avatar
Yes, in addition to moving the MLPS, as GreenBird stated, it is also connected directly to a hydraulic valve inside the transmission's valve body by a cable. The transmission is shifted via the EEC with 2 on/off solenoids, so a total of 4 different combinations are yielded for the 4 gears. Line pressure is regulated by the EEC via a solenoid. Also, you asked about "from park to drive"...I have seen a BMW with an electric parking mechanism, but in our cars, it is still done the old-skool way, with a mechanical parking mechanism connected to the shifter via mechanical linkage.
hotbird is offline
post #4 of 7 (permalink) Old 12-08-2003, 07:22 AM
Geek w/Gearhead Complex
Fubarian's Avatar
Chili, when you open it up for the mod (when we doin that anyway?), all of ^ this, will make perfect sense. Trust me.
96 Mark VIII [email protected] :: 03 radiator/fan - j-modded trans - BBK UD pulley kit - dual gauge pod - 28,000 B&M transcooler (w/ AN fits) - 3.73 locker (with speedo gear) - 180' thermo - 8.5mm wires - colder plugs
soon to install : "fixed" heads and a damn tune. Project snaked8 continues...
Fubarian is offline
post #5 of 7 (permalink) Old 12-08-2003, 07:24 AM Thread Starter
5w30 Guzzler
yeah, because of school we couldnt get to it this fall. now it's to cold to make you help me because i really doubt i can find a garage--unless you think a couple space heaters could warm up a garage.
post #6 of 7 (permalink) Old 12-08-2003, 05:56 PM
My kerosene heater did it just fine, but it was a small garage...
Now i just need a helper, the tools, and the parts :/
Vegeta99 is offline
post #7 of 7 (permalink) Old 12-08-2003, 06:54 PM
Fubarian's Avatar
gimme a call or catch me online, we'll see if we can't work something out -- shouldn't be too hard.
Fubarian is offline
