Can you shift 4r70w without linkage? - TCCoA Forums
post #1 of 10 (permalink) Old 04-20-2004, 11:56 PM Thread Starter
I know that stock applications use a floor shifter that is linked to the mlps sensor, and that the eec uses this sensor to tell the eec to shift. But, can you just do away with the mlps sensor and floor shifter completely and shift electronically using some other control means?
Worded different, same question:
Does the shift lever still control hydraulics in the transmission or is it just for controlling the mlps sensor?
Aaron
79fox351 is offline
post #2 of 10 (permalink) Old 04-21-2004, 12:02 AM
Cougar Pilot
BlackCat94's Avatar
Just for controlling the MLPS sensor
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #3 of 10 (permalink) Old 04-21-2004, 12:24 AM
Nope!, the cable is defintely there to take the car in and out of park also. With no cable, you'd never be able to put the car in park
Green95LX is offline
post #4 of 10 (permalink) Old 04-21-2004, 05:01 AM
kenshi's Avatar
It's only a 94+ that has an MLPS I'm pretty sure. I noticed you have an 87.
1994 Thunderbird LX 232
Discarded air silencer. Gutted cats. [email protected] mph at this point. 8.8" Trackloc differential with polyurethane bushings. PA manual valvebody. Sport springs.
1989 Thunderbird SC 5-speed
ESM ported supercharger. Performance exhaust.
2005 Yamaha YZF600R
kenshi is offline
post #5 of 10 (permalink) Old 04-21-2004, 07:52 AM
Boom.
Palmguy's Avatar
He is planning a 351W/4R70W combo for his car.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #6 of 10 (permalink) Old 04-21-2004, 10:02 AM
02 Explorer Pioneer
timb's Avatar
No matter what trans if you really wanted to get rid of the lever you could hook up a servo and pushbutton sytem to be real trick
Birdless
timb is offline
post #7 of 10 (permalink) Old 04-22-2004, 12:48 PM
3rd Gear Chirper
hotbird's Avatar
Yup, there is a manual valve in there also. The MLPS tells the EEC what forward gear position you're in, so it knows how/when to command a shift. It also has the neutral start and reverse light switches inside, but without the manual valve, you would have no gear engagement anyway.
hotbird is offline
post #8 of 10 (permalink) Old 04-23-2004, 03:36 AM
Sheepish
AverageJoe's Avatar
Send a message via AIM to AverageJoe Send a message via Yahoo to AverageJoe
Indeed. If you rigged up a servo, the shifter could easily be done away with. But you'd still have to have that mechanical movement of the manual shift valve.
B Team - More skill, more results. A is only a starting point before progressing to B.
Member of the 'B-Team'. Finishing jobs the 'A-Team' can't handle.
AverageJoe is offline
post #9 of 10 (permalink) Old 04-27-2004, 10:18 PM
Simple answer, yes, the shift linkage still controls the hydraulics inside the trans mechanicaly. So much for "hi-tech"!!
wrench71 is offline
post #10 of 10 (permalink) Old 05-03-2004, 11:28 PM
You'd still have the shifter or like everybody else said use a servo or air shift. But, you could just use a shifter for P-R-N-D and control the computer to shift the trans with buttons. you'd have to a Ford progammer to get that right though. But in all reallity it would be near impossible.
Clay
cman2007 is offline
