shudder/vibration in 3rd gear, but not 4th. 4r70w - TCCoA Forums
post #1 of 3 (permalink) Old 06-29-2004, 10:41 AM Thread Starter
Hello transmission people,
I have a 97 tbird, v8. I did the valvebody modification a year ( 20kmi) ago.
Now the transmission shudders in 3rd gear under a load when the torque converter is locked. It does not happen in 4th gear (OD).
Also, after accelerating in 3rd, and then letting the gas pedal off, the transmission shifts to 4th with a loud noise ( no grinding, the sound is of something hitting something else). It doesn't happen when the 3-4 shift is a power on shift. I hear/feel the same thing when the car coasts down from 3rd to 2nd gear. But it doesn't happen on a power on 3-2 shift. So basically,
I have an external cooler. The fluid is Mercon V. The fluid looks and smells normal ( for now). What could be wrong? Direct clutch? Or the torque converter? If you think it is the tc, shouldn't the transmission shudder in OD also?
Thanks for your help.
97 4.6L
1.25" front and rear anti-sway bars
j-mod
removed intake silencer
Sonner is offline
post #2 of 3 (permalink) Old 06-29-2004, 02:25 PM
Silver95Bird's Avatar
Have you ever had the TC shudder before? I'm trying to figure out if you knew what that feels like... like the rumble strips kind of feeling.
Silver95Bird is offline
post #3 of 3 (permalink) Old 06-29-2004, 02:28 PM Thread Starter
Yes I have had tc shudder before. It happened at 45kmi. I changed the fluid and it was gone. At 65kmi everything was normal. I changed the fluid, and did the valve body mod. Now at 85kmi it is doing it again, but only in 3rd gear and as I described it in my first post.
Soner
97 4.6L
j-mod
Sonner is offline
