J-Modding an 99+ GT 4R70W - TCCoA Forums
post #1 of 13 (permalink) Old 07-31-2004, 07:28 AM Thread Starter
I just have a few questions on what is different between J-Modding the 96-97, to the 99+ GT 4R70W?
Are all the same hole openings the same specs?
Does anyone have the specs for the 300 - 450hp setting(I found them but there are different ones for 94/95/96/97, which do I use?)
Accumilators the same? Change out same ones?
Any other advise concerning J-Modded 99+
Thanks In Advance
Dave
DMcBrideBoston is offline
post #2 of 13 (permalink) Old 07-31-2004, 09:23 AM
You don't have to change the accumulator pistons since it will already have the new ones. You can, however, remove the bottom 1-2 spring and 2-3 springs to firm up the shifts.
I just did my Mark VIII to the 300-450hp range. Here's the holes I did:
Hole #1: .160"
Hole #2: .100"
Hole #3: .180"
Hole #4: .100"
Hole #5: .100"
Hole #6: .125" (you want to enlarge this one to the slot in the gasket)
Hole #7: .125"
Hole #9: .089"
Hole #11: .089"
Here's Jerry's info on modifying the main control:
Page 13 and Page 14
pestlnc is offline
post #3 of 13 (permalink) Old 07-31-2004, 09:47 AM Thread Starter
Dave
post #4 of 13 (permalink) Old 07-31-2004, 09:56 PM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
dave see if the place that is installing your new trans will let you have your old valve body. you can probably sell the jmod'd separator plate on here
frank
2007 Dodge Ram 1500
2008 Suzuki GSX-R1000
Previous Rides:
2003 Suzuki GSX-R750
1990 Thunderbird 3.8 - Slower
Fdawg03SVT is offline
post #5 of 13 (permalink) Old 07-31-2004, 10:09 PM Thread Starter
Planned on it, Jim out in Ayer is doing the swap.
Thanks Frank
Dave
post #6 of 13 (permalink) Old 09-04-2004, 07:50 AM Thread Starter
Do I need to swap in the updated blue 1-2 spring or is it already in there?
Thanks Alot
Dave
post #7 of 13 (permalink) Old 09-04-2004, 10:28 AM
Formerly Fdawg97LX
Fdawg03SVT's Avatar
should already be in there. all u gotta do is drill the plate and pull the 1-2 bottom spring and the 2-3 spring.
Frank
2007 Dodge Ram 1500
Previous Rides:
post #8 of 13 (permalink) Old 09-04-2004, 12:07 PM Thread Starter
Thx...
post #9 of 13 (permalink) Old 09-04-2004, 05:40 PM
Like Titles Matter
kdanner's Avatar
Do not count on a certain accumulator spring to be there, they vary from model to model.
kdanner is offline
post #10 of 13 (permalink) Old 09-04-2004, 09:21 PM
Good post. My 01 GM trans has a green upper 1-2 spring in it. Grabbing the blue one from my old 95 as it comes out.
FordMan77 is offline
post #11 of 13 (permalink) Old 09-04-2004, 09:32 PM Thread Starter
Does this go for the accumulator pistons also, or just the spring?
Dave
post #12 of 13 (permalink) Old 09-04-2004, 09:35 PM
To the best of my knowledge, you should have the updated pistons in there already. Just pull/swap the springs, and you should be set.
post #13 of 13 (permalink) Old 09-05-2004, 07:35 AM Thread Starter
Thanks Alot guys,.....better to be safe than sorry.
Dave
