4R70W PA Super Streeter 1-2 concern - TCCoA Forums
post #1 of 11 (permalink) Old 09-29-2004, 03:13 PM Thread Starter
I have a brand new PA Super Streeter installed recently and there is something weird going on 1-2 shifts, some kind of vibration from the rear end, feels exactly like wheel hop (less prominent of course) when you race a quarter and traction is not consistent and there is some grabbing and spinning on launch.
Fluid level is fine, it's Mercon V, and it does this with different torque converters.
Sort of like momentarily tire scrubbing loss of traction, assuming that it comes from tires, but after reading about that infamous TC shudder I'm not 100% positive that it's not a tranny problem. May be it shifts just a bit different than stock with J-mod and locking tires on 1-2 shifts?
This is what's included in the Super Streeter package
HEAVY DUTY CLUTCHES,
HEAVY DUTY SERVO,
STREET/STRIP VALVE BODY
KEVLAR BAND
DRUM
DIODE
Thanks in advance for your help.
Andrew WOT is offline
post #2 of 11 (permalink) Old 09-29-2004, 03:54 PM
Silver95Bird's Avatar
in 1st gear the TC is always unlocked, so that's not it. I don't see anything in the EEC program that would cause that either. Some times these 'high performance' transmissions still use the aluminum accumulators with o-rings (these were such junk that Ford hasn't made any of them after 98). Should one of these be leaking it would delay or otherwise make the 1-2 shift weird.
It's also possible the trans is not the problem at all. Trans mounts, rear end issues, etc should also be checked too.
Silver95Bird is offline
post #3 of 11 (permalink) Old 09-29-2004, 04:44 PM
Maybe it's your traction control? If you have this option. If so, turn it off (the button should be on the front console near the shifter lever) May be labeled as "traction assist" as well, can't remember. Mine had an issue similar to yours, and when the trac. control was off, it went away.
FordMan77 is offline
post #4 of 11 (permalink) Old 09-29-2004, 08:22 PM Thread Starter
Thanks guys for your replies.
It's 98, so no traction control. And it started to happen only after the new tranny was installed.
What kind of rear end issues could that be, what should I look for?
Thanks again.
post #5 of 11 (permalink) Old 09-29-2004, 09:16 PM
See if there's excessive play in the diff (the clearances are tight, there shouldnt be a lot of free play), loose driveshaft bolts, worn shocks... anything in the suspension that is moving when it shouldn't. Maybe a second person could watch/listen when you launch. They may see something you can't from inside.
post #6 of 11 (permalink) Old 09-29-2004, 10:03 PM Thread Starter
Looks like the phenomena I'm experiencing is just a wheel hop. Why does it do this with the new tranny I have no idea. May be it just shifts harder, the car definitely squats on 1-2 shift even under moderate throttle and I have pretty stiff suspension setup with Tokico adjustables on 5.
I'll try to remove my quad-shocks they might be worn out plus with MM LCA they are more like just extra weight anyway, right?
post #7 of 11 (permalink) Old 09-30-2004, 08:52 PM
TMcColl's Avatar
Send a message via AIM to TMcColl
Where did you get this transmission and what was cost?
I will be in need of a tranny some time in the not to distant future.
Tony
Tony McColl
1994 LX 4.6L
New motor as of Aug 1st.
No Dyno Numbers yet.
Just two runs at 5800 ft.
http://www.cardomain.com/ride/2203515
TMcColl is offline
post #8 of 11 (permalink) Old 10-10-2004, 12:33 PM Thread Starter
Took off quads.
Didn't help much with the wheel hop at first, but then I went for WOT run, car shifted a couple of times really hard and.... something changed, shifts are totally different now, lightning fast and firm. I can't believe auto tranny could be so quick. It's literally blink of the eye shifts, and I'm talking part throttle here, and no even a hint of wheelhop in fact car handles better without quads
It clunks a bit on 2-3 shifts though. Wondering if this is normal?
And what the hell has happened that changed the whole nature of the tranny?
post #9 of 11 (permalink) Old 10-13-2004, 08:15 PM
Paddycake's Avatar
could be your driveshaft....
No matter how good she looks. No matter how cool she is about your "stuff". No matter how great she is in bed, someone somewhere is sick of her crap.
1995 850R with 18T, 3" downpipe, R.I.P. kit, ported intake,42lb injectors, N/A cams, 960 throttlebody, Rica tune(15psi in first and second 17psi in third and fourth). Bilsteins all around, V70R caliper and rotor upgrade, total lack of traction. IPD STB, Ultra Racing lower braces and RSTB.
Paddycake is offline
post #10 of 11 (permalink) Old 10-13-2004, 09:13 PM Thread Starter
You mean clunking?
Didn't do this with old tranny and J-mod.
post #11 of 11 (permalink) Old 10-15-2004, 05:32 PM
Lazania's Avatar
who installed this tranny??, check the trans mount. I dont see anything in the trans that would make your car jump like wheel hopping does. Check your IRS bushings too.
2011 Mustang GT Premium 6spd
Current Modifications:
C&L Cold Air Intake
Catted X pipe
MBRP Mufflers
Custom Street Tuned
Lazania is offline
