AOD with 4R70W gearset - TCCoA Forums
post #1 of 8 (permalink) Old 12-10-2004, 02:52 AM Thread Starter
coleman's Avatar
Question AOD with 4R70W gearset
I am looking at putting the 4R70W internals into an AOD case. This appears to be a popular upgrade - I believe it can be done without using a transmi$$ion shop.
What I have:
AOD from 1988 Mustang (blown front seal - clutches toast)
4R70W from a rolled 1996 Explorer (cheap!!)
(This is for a 91 Sport with a 302)
What I don't know is what do I have to keep from the AOD?
Case - The Explorer had a 5.0 (no, I didn't get the intake, TB, or heads)
Input shaft?
Valve body - the Explorer one is electronic.
Anything else??
What I would like is a relatively inexpensive, improved AOD.
I've seen several references to this particular build-up, but nothing really specific about which parts to retain. (I have read the Tech articles, and been over to SCCoA, and numerous other sites). As far as I can tell - I'll figure it out once they are apart, but I could REALLY use a headstart!!!
Mike
coleman is offline
post #2 of 8 (permalink) Old 12-10-2004, 09:01 AM
I put the 4R70W gears in my aod when I built it and I didn't have to get
any special parts in order for it to fit...
However, I should mention that I had a tranny shop put it all together...
I you want info in what I put in check out www.mn12racing.com
and click on mods..
There you find my parts list and a complete list on upgrades that are available..
for example mechanical diode and so on..
//Per
Thyg0d is offline
post #3 of 8 (permalink) Old 12-10-2004, 01:17 PM
Silver95Bird's Avatar
You'll still want a reverse drum/mechanical diode from a 98+ trans, that roller one-way version will fail. Get the spiral lock ring from makco to go with it.
Silver95Bird is offline
post #4 of 8 (permalink) Old 12-10-2004, 02:03 PM
Johnny Five is Alive
WkStill's Avatar
Send a message via AIM to WkStill Send a message via Yahoo to WkStill
i believe those are GT40 Heads on that 302
Any other parts for sale off it?
I would be willing to purchase the Cam Sensor & Harness
1984 Merc Cougar
5.0L, GT40X HEADS, E303 CAM,X303 Valvetrain
1998 4R70W Controlled by Baumannator TCS., 3.73 Track Lock Rear., Bauman Lev 3 Shift Kit.
190LPH, 67mm EGR, 65mm TB, 73mm C&L MAF, 24lb/h Inj, TwEECer RT, A3M EEC-IV
TCCoA-AHole Crew 2004
Disclaimer: The opinions expressed in my posts are my own. They are not meant to start a flame war or discourage people. Just my honest opinion and nothing more
Just great, 4 mores years of GOP crap, Im republican, and I endorse this message
WkStill is offline
post #5 of 8 (permalink) Old 12-10-2004, 08:18 PM Thread Starter
coleman's Avatar
Is the roller really that bad? I figured it HAD to be better than the stock AOD garbage.
I'll look into locating a cheap source - junkyard or parts house (for the mechanical diode). The spiral lock is not OEM, is it?
Originally posted by Thyg0d
... check out www.mn12racing.com
and click on mods..
Thanks for the link - you've spent more on your tranny than I have on my car!!
Originally posted by WkStill
... Any other parts for sale off it?
Actually - yes, there are more parts for sale. I'll have to check on the Cam Sensor and harness. I was not able to get the engine (or GT40 intake or GT40 heads) My buddy did! I know the tan leather Eddie Baur interior needs to go - its in the way!!
Thanks for the tips.
Mike
coleman is offline
post #6 of 8 (permalink) Old 12-11-2004, 12:09 PM
This is what happens to the roller one-way clutches:
AODE's and a good number of 4R70W's got the same garbage AOD roller clutch. Some later taxi CV's got a 14 roller version instead of the 7 roller, but it didn't seem to make much difference. I added the MD to my CV's AODE when I rebuilt it, it added about $100 to the cost but I consider it well spent for the piece of mind. The snap ring was from www.bulkpart.com
post #7 of 8 (permalink) Old 12-11-2004, 12:44 PM
Well... If you ad shipping, taxes and a rebuild cost of $650
I think it ended up costing me around 2400 bucks...
Silverbird:
Ouch! That must have made a nice sound when it broke...
//Per
Thyg0d is offline
post #8 of 8 (permalink) Old 12-11-2004, 10:18 PM Thread Starter
coleman's Avatar
...I added the MD to my CV's AODE when I rebuilt it, it added about $100 to the cost but I consider it well spent for the piece of mind. The snap ring was from www.bulkpart.com
Learning from someone else's experience is definately cheaper. I will heed your advice!! Thanks for the link - I have done business with them in the past. My dad-in-law and I upgraded a couple AOD's to the specs listed on the SCCoA (that one really long AOD thread between mike38 and duanemyre).
Unfortunately, after I installed the shift kit, the front seal blew out within 75 miles. It may have been because I was rompin it pretty hard....nah!!!
Yep - more than I'm into mine for!!
Mike
coleman is offline
