HOW TO: 03 4R70W into an SC - TCCoA Forums
post #1 of 53 (permalink) Old 12-10-2004, 10:27 AM Thread Starter
There are very few things that you will have to change to do this, so here it goes.The good thing about using these 03 trannys are that it already has a Mech Drum installed in it, and that in 03 Ford started Brazing in the TC, and they have worked out all the little kinks ours a prone to having.
1:You will need to remove the tranny #1 rule PB blaster will help loosen any bolt if its a high milage car.
drain tranny and torque converter before beginning. about 12 quarts worth.
1. Take off exhaust from manifolds back. Need to take a little crossmember off in order to do this, you'll see it when you get under there.
2. Take off all heat shields. And remove the 2 driveshaft saftey loops.
3. unbolt driveshaft.
4. Lower gas tank (with a jack supported by a wood board, the bigger the better also helps if its 1/4 tank or less.) by the 4 bolts holding it on with 2 straps, also a good idea to remove the bolt from the filler tube right near the spring. Slide out driveshaft.
5. mount gas tank back in place.
6. remove negative battery terminal and remove starter, (BIG sparks if it's not unhooked)
7. unclip the wiring harness, and throttle body valve linkage. If I remember right it's not a good idea to take off the neutral switch.
8. remove bellhousing bolts leave 1 on each side to hold it in place for the time being.
9. remove fluid coolant lines
10. place tranny jack/ jack with a board on it to support the crossmember and pan at the same time, I found this to make it easier to balance on the jack.
11. support engine by oil pan with a block of wood to distribute the weight. unbolt torque converter from flywheel. you have to turn the engine over with a breaker bar by the crank pulley to get to the 4 bolts.
12. unbolt the crossmember by each side then take out the 2 bolts on the bellhousing.
13. have a friend hold the tranny steady while you SLOWLY slide it off the pins and lower it, as it goes down you can actually sit under the car.
14. reverse to install. remember that the throttle body valve linkage is very sensitive to adjustment DO NOT tinker with it or you'll be doing the same thing all over again real soon.
(Steps from Tony8470)
Now while the tranny is out here is where you will be doing a few changes. You will be changing the pinout on the main transmission connector, the TCC solenoid, and MLPS.
#2: while tranny is removed you will want to take the pan off your 03 tranny to replace the tcc solenoid. you will have to remove the black piece shown here in yellow, to get to the TCC Solenoid.
#3: Now you will need to repin the transmission connector, this is what it looks like
now this is what the repin should look like when done, courtesy of Big Scott
this is what mine looked like, i just taped up the extra 2 power wires.
now there is a whole write up on the pinout located here
#4: Now because we could not think of any other way at the time we changed out the linkage cable end with the one on the old tranny(the 03 uses a sqaure piece vs the sc which uses the ball)
#5 This box(OSS) also needs to be changed out with the old one,
And thats it install your new tranny, make sure to fill it up with fluids.
I must also give credit in this post to Big Scott for the correct pinout, and to dirtyd0g aka Allen ? who is a tranny and Converter Guru(he makes them), i would recomend him for anything having to deal with your tranny, he is the one who first started me on my quest, and helped me a ton along the way, really a great man. And also to Racecouger AKA: Rod, who helped me in the heat of installing, who climbed out from working on a car to help me out, and for his posts which eventually got me headed in the right direction. And one last one, Birdman93 AKA Tony Poole, who guided me over the phone while he was online trying to find a answer and explain it to me during a problem(that was fun ) and anyone else i have forgotton.
Without the members of a community like this, i would have never been able to do this, thank you all. And to the members who were not in on this, thank you!(for my future problems )
Hope this helps someone sometime
If i have forgotton anything please tell me.
Tyler
post #2 of 53 (permalink) Old 12-10-2004, 10:34 AM
Automatic Weapon
Big-Al's Avatar
This has Tech article written ALL over it!
<----not throwing rocks at girls anymore
Big-Al is offline
post #3 of 53 (permalink) Old 12-10-2004, 10:46 AM
Like Titles Matter
kdanner's Avatar
Rather than tape up the 2 extra wires, I put them into the 2 leftover holes in the connector. The trans half of the connector has no pins in those 2 locations, so no issues.
"This box" is the OSS.
Have you verified your speedo is correct or even working yet? It certainly should be incorrect at best unless you installed a speedcal. I have a feeling it is not going to work at all though.
kdanner is offline
post #4 of 53 (permalink) Old 12-10-2004, 10:48 AM Thread Starter
Speedo works just fine, it is however a little bit off, not by much, i havnt tested yet to see how far off it is, but i can always replace the speedo gear when i get around to it. Thanks for letting me know about that box also
Tyler
post #5 of 53 (permalink) Old 12-12-2004, 10:02 AM
Do you have to replace the OSS for all 99+ transmissions, or just the 03+?
SloMo228 is offline
post #6 of 53 (permalink) Old 12-12-2004, 11:08 AM
Blackicelsc's Avatar
Send a message via Yahoo to Blackicelsc
Tyler...excellent job. I was going to do the same thing when I installed my 98 tranny into my 94 mark VIII.
I also had to move my linkage rod over from my 94 to the 98 since the 98's was a round hole, instead of a squared off "lock" style.
nice pics....except I didnt remove the driveshaft...I removed the front U-joint from the yoke, and shaft, and just moved the D/S up and out of the way. This saved me A TON of time. as I dropped the tranny, it easily cleared the D/S flange. Then, just replace the U-joint while the tranny is out, and the yoke is in your hand anyway(from one tranny to the other). Then, install the new U-joint to the D/S flange when it goes back in. No tank drop, and barely any exhaust drop.
My speedo is also off(by 10 mph at 75-it sais 85). I assume since the Mustang tranny I got came from a 3.27 car, and went into my 3.08 car.
Very nice job.
SloMo, did you do everything in this article correctly? if so, then I think the pin-out connector must be your only problem.
Blackicelsc is offline
post #7 of 53 (permalink) Old 12-12-2004, 11:18 AM
Tyler I have sort of bad news for you. The supercoupe motors are neutral balance, meaning you can install a markVIII flexplate on them and the marauder converter. Sorry I didn't know this sooner I never really looked into the 3.8 balance setup until recently. I am still not sure if all 3.8's are neutral balance,but apparently the SC ones are.
post #8 of 53 (permalink) Old 12-12-2004, 12:25 PM
Silver95Bird's Avatar
So your speedo works? We keep getting conflicting reports about 03+ trannies not having the gear on the output shaft the VSS meshes with. I wish we could get some pics of the 03+'s to verify wth is going on there.
Silver95Bird is offline
post #9 of 53 (permalink) Old 12-12-2004, 01:03 PM Thread Starter
yes the speedo works, ill see if i can find a good pic for you, but i can tell you for sure that the shaft is there, there is a black plug covering it, you just have to open your eyes a bit and unscrew the 2 screws , then its all good from there.
Tyler
post #10 of 53 (permalink) Old 12-12-2004, 05:55 PM
I did everything in this write-up except changing the OSS. Is that something that I should have done? I don't remember reading anything about it anywhere for a 99 transmission. My classes are finally ending soon, so I'll have some time to try and fix this bugger once more.
SloMo228 is offline
post #11 of 53 (permalink) Old 12-12-2004, 06:40 PM Thread Starter
what is yours doing? make sure you check and recheck your pin job! Im not so sure about the OSS, Alan AKA DirtyD0g may know. I know that this works as i wrote it for a 03 Tranny, i really honestly have no idea, what is different about the 99 to the 03 except for the brazed in TC.
Tyler
PS:im still looking for that pic
post #12 of 53 (permalink) Old 12-12-2004, 07:02 PM
Dim Bulb
Falcon5783's Avatar
I'm just wondering what the advantage or gain is of doing all the work you did?
+1
Elliot
Falcon5783 is offline
post #13 of 53 (permalink) Old 12-12-2004, 08:22 PM
JustinH's Avatar
thats an early supercoupe with a 4r70w?
How does that work with the computer?
The sc didn't get the 4r until 94, and your car looks like one earlier than 93.
JH
JustinH is offline
post #14 of 53 (permalink) Old 12-12-2004, 08:32 PM
I was thinking that too. Those are pre-94 SC wheels on it, but it's a 94-95 SC. Look at the front bumper.
SloMo228 is offline
post #15 of 53 (permalink) Old 12-12-2004, 08:44 PM
JustinH's Avatar
oh the wheels threw me off. I looked at the lights, and it looked like a 93 for some reason to me.
The side body trim gives it away as a 94-95.
JustinH is offline
post #16 of 53 (permalink) Old 12-13-2004, 05:14 AM Thread Starter
Falcon5783 I'm just wondering what the advantage or gain is of doing all the work you did?
Falcon5783 Im sure that Alan could chime in a little more about whats better since he is the tranny guy.Somthing i think i forgot also is that they have a wide gear ratio, but hopefully Alam will chime in here, and explain all the differences, i know that he made a post somewhere about the advantages of the newer tranny, try a search. It has been awhile since i talked with him on the phone and thats when he really convinced me to go with the newer tranny. Plus i paid $400 for this 03 tranny with 7k miles on it, rather than a rebuild which was $1400.
Tyler
post #17 of 53 (permalink) Old 12-13-2004, 06:24 AM
Darrin's Avatar
Well, the 03 tranny has a case that is designed to provide better exhaust for the forward clutch, the newest style accumulators and it is simply stronger than the 94 case that was in his car.
The valve body has had several changes to help the converter and provide better shifting. It also has a nicer setup for the electronics, no wires.
The biggest thing is that it just has the best of the best parts available in a factory Ford transmission and it is better suited for a performance buildup because it already contains the strongest gearset. The 94-95 gearset was by far the worst. The 96 and up were better, but this one has the same gearset as the 5.4 so it is stronger yet.
There are some other things including better design frictions and different stacks on the clutch packs, but the above are the most important items.
Hope this helps
Darrin is offline
post #18 of 53 (permalink) Old 12-13-2004, 06:38 AM
What he said he builds transmissions for me.. As far as the OSS goes I don't know of any difference in them. The VSS requires that there is a place on the output shaft to runs it. I looked at 3 03 4r70w's the other day at a local salvage yard and all of them Had it. They had an 04 that did not have it. The best I can tell is that if the extension housing does not have a hole in it the shaft has no teeth. If it has a little plastic plug on it there are still teeth in there. I highly recommend you check these things before buying a transmission.
post #19 of 53 (permalink) Old 12-13-2004, 06:55 AM
Darrin's Avatar
I forgot to say that I think that most all of everyone on this board will not need that 5.4 style gearset. You would have a much bigger problem with our IRS setup before you could even begin to worry about breaking the gearset.
But, the change from the 94-95 gearset to the 96 and up is the most important if you want it to last. I wouldn't use the 94-95 gearset for anything in my opinion.
Darrin is offline
post #20 of 53 (permalink) Old 12-13-2004, 08:42 AM
Yeah, I'm not a fan of those aluminum bushings in the early gearsets either.
post #21 of 53 (permalink) Old 12-13-2004, 11:00 AM
I thought the biggest issue with the early gearsets was the sun gear. I have yet to find an early one that wasn't bad.
post #22 of 53 (permalink) Old 12-13-2004, 12:14 PM
not to mention the mechanical diode as opposed to a roller, and the 94-95 TC's were pretty sloppy.
I went with a 98 Mustang tranny in my 94 mark VIII for a couple reasons. Price, the fact that it had already been "built up", and TIMING...I needed it yesterday, and got it at the exact moment there was a SCREAMIN deal on a '03 Mach 1 TC.
sometimes you get lucky, and with the help of the right people, things come together.
right people= Alan, Johhny L, Silver95, and Andrew WOT.
post #23 of 53 (permalink) Old 12-13-2004, 12:43 PM
Darrin's Avatar
And for what most people on here need, that 98 is just fine. I don't know if the sun gear changed in 96 or not, I wall have to look that one up. I admit I was talking about the bushings switching from aluminum to brass.
Yup, the MD was a change made sometime in the 97 model year. All 98 and up have them. We weld the snap rings on the ones we build.
Darrin is offline
post #24 of 53 (permalink) Old 12-13-2004, 04:02 PM
Ashish's Avatar
Send a message via AIM to Ashish
dirtydog, I have a question regarding the plug you are talking about on the extension housing. Is this the same area where the speedo gear goes in our 97 trannies. I just want to make sure I am looking at the right area. I might be gettin a 03 tranny pretty cheap.
1997 Birdie, its the good one. Limited Edition Sport Sold
9/6/03-9/7/03-J mod & Mark VIII TC 12/26/03-Apten Chip & 03 GT MAF 3/11/04-3/14/04-PI Cams & PI Intake 8/19/04-FRPP 3.73 Diffy2/26/05-SCT chip (burned by Ken B.)
1998 Z28 M6 5.7 LS1
Ashish is offline
post #25 of 53 (permalink) Old 12-13-2004, 04:30 PM
Ashish, Yes thats what I am talking about before you buy the unit make sure there are teeth inside there. I can almost guarantee if there is no hole there are no speedo teeth. Everyone I have looked at without a hole had a blank area instead of teeth. Just to be safe remove the 7/16 head bolt and plastic cap and look inside.
post #26 of 53 (permalink) Old 12-14-2004, 03:23 AM
Dim Bulb
Falcon5783's Avatar
Thanks Darrin, your answers helped a lot. I've got a 95 and I had to rebuild my trans at 65K. If I'd been on the forums then I seriously would have considered doing this swap. My question now is if/when I build up a 4.3 stroker engine, how much hp is that trans setup rated for?
+1
Elliot
post #27 of 53 (permalink) Old 12-14-2004, 09:58 AM
TCCoA Preferred Vendor
Send a message via AIM to blk mk8
i though the 3.8 had a 5.0 bell housing pattern. unless you are talking about using a newer mustang auto tranny.
OWNER of Accelerated Race Technoligies
www.speedfreak.cc
blk mk8 is offline
post #28 of 53 (permalink) Old 12-14-2004, 11:22 AM
It does.
post #29 of 53 (permalink) Old 12-16-2004, 03:34 AM
Dim Bulb
Falcon5783's Avatar
Originally posted by Falcon5783
How much hp is that trans setup rated for?
bump, just wondering
+1
Elliot
post #30 of 53 (permalink) Old 12-16-2004, 05:22 AM
Darrin's Avatar
There is no way to answer your question unless you ask the builder short of taking it apart and inspecting it.
Darrin is offline
