4R70W Internals?? - TCCoA Forums
post #1 of 12 (permalink) Old 12-14-2004, 10:38 AM Thread Starter
4R70W Internals??
There is a fella that lives close to me that has some 4R internals. I would like them for my next AOD build. I know how to check for the Mech OWC, but how do i tell if it is the Low gear set? Anything else I should look for to verify?
The 4R came with both the high and the low and early models had the roller OWC. He said it came out of a Van, but I have been told that there were no 4R's in vans.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #2 of 12 (permalink) Old 12-14-2004, 11:50 AM
The ring(gear) that connects to the output shaft on aod and aod/e's is smooth on the outside and slightly smaller than the 4r70w version. the 4r70w is larger so it has a machined down edge in it to prevent it from hitting the case. The easiest way to identify them is by that ring gear.
post #3 of 12 (permalink) Old 12-14-2004, 01:10 PM Thread Starter
The ring......gear.....do you mean the drum that is attached to teh output shaft. I am not familure with a "gear" that is connected.
post #4 of 12 (permalink) Old 12-14-2004, 04:48 PM
Yes that is the piece. It is not technically a drum because it has gear teeth in it and is part of the planetary assembly. It has the direct drum inside of it.
post #5 of 12 (permalink) Old 12-14-2004, 08:08 PM
Silver95Bird's Avatar
Well, according to jerry's article, only mustangs and crown vics/GMs/TCs came with the AODE - so if it's not from one of those built before 1996 then it will be a 4r70w.
Silver95Bird is offline
post #6 of 12 (permalink) Old 12-15-2004, 07:54 AM Thread Starter
I have asked before,,,,,it there a way I can reach this jerry guy? I have a few technical questions. e-mail or somthing?!!!
post #7 of 12 (permalink) Old 12-15-2004, 01:21 PM
He's a little busy running a chip company and dyno tuning a few thousand cars...
post #8 of 12 (permalink) Old 12-15-2004, 01:35 PM Thread Starter
Busy...........No man is bussy for a beer and chat. WHere is he.
post #9 of 12 (permalink) Old 12-15-2004, 02:46 PM
JustinH's Avatar
you are best off buying a newer junkyard 4r transmission than buying parts seperate.
All the hard parts are going to cost more than a 300 dollar junkyard trans.
JH
JustinH is offline
post #10 of 12 (permalink) Old 12-15-2004, 03:10 PM Thread Starter
I hear ya there. but these parts are just loose out of the tranny, I assume he wants next to nothing for them. I have kinda abondoned the idea of putting them in my AOD since it would require me to swap out the gears I JUST PUT IN!!!!! I put in 4.10's and the 4R ratio would make it a 4.8!!!! That is a little high for a stock 5.0. I also would have to downgrade my governor......
post #11 of 12 (permalink) Old 12-15-2004, 04:32 PM
If you say so. Personally I think the aod gearset should be destroyed and all of the 4r70w gearsets installed in all of them.
post #12 of 12 (permalink) Old 12-15-2004, 04:35 PM Thread Starter
You are correct that they are crap....but hey....after I install this stuff the tranny will be back here on the Classfieds for you all to grab........maybe
