revving during 3-4 shift 4r70w - TCCoA Forums
post #1 of 11 (permalink) Old 06-09-2005, 08:29 PM Thread Starter
hi, i have a 3500rpm stall edge converter, with a PA valve body.
when i'm driving, the 3-4 shift always revs a little, about 500rpm. this is barely on the throttle. if i turn OD off and on, sometimes it will rev, sometimes it wont.
is this a major problem, or should can the chip fix this?
btw, never WOT'd the car yet, hasn't been on the dyno yet.
also, a little off topic, should the line pressure be raised even though i have the valve body?
xomp is offline
post #2 of 11 (permalink) Old 06-09-2005, 10:52 PM
I suggest you make sure you have the large OD servo and it would be a good idea to change the OD band. They are always fried. If that doesn't fix it put the stock converter back in because it has a better clutch.
post #3 of 11 (permalink) Old 06-10-2005, 12:24 PM Thread Starter
hm.. well.. it drove completely fine when i didn't have the converter or the valve body. it's too bad i put them in at the same time.
i'll probably do the OD servo, j-mod springs and accumulators while i'm at it, as i think PA only supplied the 1-2 and 2-3 servo springs.
xomp is offline
post #4 of 11 (permalink) Old 06-10-2005, 12:30 PM
Silver95Bird's Avatar
I suggest you read A-train's articles on the J-mod if you're replacing the OD servo - they are tricky to get in place right. If you get it wrong, you'll have to do it all over again.
Silver95Bird is offline
post #5 of 11 (permalink) Old 06-10-2005, 12:42 PM Thread Starter
ok, thanks!
xomp is offline
post #6 of 11 (permalink) Old 06-10-2005, 01:32 PM
Like Titles Matter
kdanner's Avatar
Try this. After the 3-4 shift completes, keep the throttle steady and just tap the brake pedal enough to activate the brake lights, the converter will unlock then relock. If this feels exactly like what you are already feeling, then it's your calibration and/or the inability of that converter clutch to lock, you're feeling the converter clutch modulation for the upshift. If it feels different, then yes your OD band is slipping.
kdanner is offline
post #7 of 11 (permalink) Old 06-10-2005, 02:22 PM Thread Starter
so basically, holding it in OD at constant throttle, then tapping the brake should cause the engine to rev slightly (-IF- the OD band is good)?
xomp is offline
post #8 of 11 (permalink) Old 06-10-2005, 03:26 PM
Tapping the brakes unlocks the torque converter, and allows the RPMs to jump a little. Kdanner is saying that when you do this, does it feel the same as on the 3-4 shift? If so, it might not be the OD band; it might be the program or the converter clutch. If it feels different, it's probably the OD band.
Tobey is offline
post #9 of 11 (permalink) Old 06-10-2005, 04:44 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
That's exactly what he said.
JL
Fuelly
Johnny Langton is offline
post #10 of 11 (permalink) Old 06-10-2005, 04:53 PM Thread Starter
ok, just wanted to clarify.
damn, you guy's are all over this.
thanks a lot for the help, i'll give it a try when i get back from work.
xomp is offline
post #11 of 11 (permalink) Old 06-11-2005, 07:56 PM Thread Starter
hm.. well tried it like 10 times.
I'm not sure if i'm doing it right, but when i pushed the brake while in OD, I don't feel anything, seems to drive normally.
could it be the valve body and would it be a good idea to do the jmod/servo? i don't wanna waste my time if the band is probably dead.
xomp is offline
