4R70W missed second gear - TCCoA Forums
post #1 of 12 (permalink) Old 06-14-2005, 10:15 AM Thread Starter
First time this has ever happened. 1994 SC under WOT in Drive this morning, missed second gear. I let off the throttle and as the rpm's came down, second caught and I thought I heard some rattling, but the car has driven fine since. Approximately 90,000 miles, tranny cooler, mercon V, no shudder. I know my 1st-2nd accumulator spring needs replacing since I've got a late-hard 1st-2nd shift, but it's never MISSED the shift before. Any ideas as to the cause/solution?
Black 94 SC
Black 95 SC
Black94SC is offline
post #2 of 12 (permalink) Old 06-14-2005, 10:30 AM
Toombs's Avatar
My guess....you've spun the roller clutch. No mechanical diode in your transmission...yet. I had the same problem a while back in my 94. It'll get steadily worse until it just won't hold second gear under any kind of throttle. I never let it get that far, but you'll need to either rebuild and update or replace your tranny with a newer one.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- DirtyDog Converter (3,800)
- SCT Micro Tuner from Blue Oval Chips
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #3 of 12 (permalink) Old 06-14-2005, 10:31 AM
Darrin's Avatar
Also, the 1-2 accumulator may have stuck in the bore. You need to get in there and replace the accumulator pistons and springs, soon!
Darrin is offline
post #4 of 12 (permalink) Old 06-14-2005, 02:27 PM Thread Starter
I'm just procrastinating - I took the mercon bath once already. I didn't know anything about this web site and the information regarding the 1-2 accumulator spring when I changed the transmission fluid the first time or I would have done it then. The magnet looked like a doughnut with all the filings that were stuck on it. I'm assuming a lot of it must have been from the 1-2 accumulator piston rubbing on the bore. Seems like everything is breaking at once on this dang SC.
No problem this afternoon on the 1-2 WOT shifts though.
Black 94 SC
Black 95 SC
post #5 of 12 (permalink) Old 06-14-2005, 02:31 PM
Toombs's Avatar
That's the way mine started too. It did it once, and then didn't do it again for a long time. And it only does it under very heavy load. It got to where it would do it maybe 2 times in ten, then it did it once at WOT in the middle of a race, and it spun the roller clutch pretty bad. It drove fine all the way home, under light throttle, and then I pulled the tranny that week.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #6 of 12 (permalink) Old 06-14-2005, 02:49 PM
Darrin's Avatar
The stuff on the magnet isn't from that. The case is aluminum and the piston is aluminum so the magnet wouldn't catch it.
Darrin is offline
post #7 of 12 (permalink) Old 06-14-2005, 03:55 PM Thread Starter
You're right. I didn't think of that. I guess my transmission is just grindng itself to pieces - bit by bit.
Black 94 SC
Black 95 SC
post #8 of 12 (permalink) Old 06-14-2005, 04:04 PM
Darrin's Avatar
LOL, it's a 94. They are good for that.
Darrin is offline
post #9 of 12 (permalink) Old 06-14-2005, 04:23 PM
FordFanatic's Avatar
yup, that sounds like what mine did.
FordFanatic is offline
post #10 of 12 (permalink) Old 06-14-2005, 04:41 PM
ptschett's Avatar
Sounds like mine too. I'm thinking I'm going to be looking into late model wrecked-Mustang trannies.
1996 Ford Thunderbird 4.6L/auto, 195k miles, semi-retired
2005 Dodge Dakota Club Cab 4x4 4.7L/auto
2015 Dodge Challenger R/T 5.7 Hemi/auto
Gone but not forgotten: 1973 Mercury Cougar XR-7 351C-2V/FMX - 2010 Dodge Challenger R/T 5.7L/manual
ptschett is offline
post #11 of 12 (permalink) Old 06-14-2005, 06:05 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Another roller one-way clutch on the way out...
JL
Fuelly
Johnny Langton is offline
post #12 of 12 (permalink) Old 06-14-2005, 06:10 PM
must be an epidemic around here lately. oh well, keeps darrin busy.
