Question on AOD - AOD-E/4R70W - TCCoA Forums
post #1 of 27 (permalink) Old 08-30-2005, 01:31 AM Thread Starter
Ok sorry but ya I'm a newb and I'm not 100% sure this belongs in the newb section or not so try not to burn me too bad
From everything I've read so far I have the "old" AOD transmission which is known to have "problems" I started searching for transmission info in the forums and I believe I've confused myself as much as I've cleared things up.
Is the AOD-E/4R70W a TOTALY DIFFERENT TRANNY then the AOD?
If so is it one that is easily found or purchased to be used incase mine goes or I simply want to "upgrade"? And also if so is it worth it?
Now I saw in some places it was more or less put as a 4R70W modification to the current old AOD. Is that more or less doing the new tranny with the old block or is it the gears?
My biggest worry is that my trans will go soon *especialy with my crazy driving* and I don't wanna be stuck without a clue what to do. This car has its original trans, 123k+ miles now, and the tv cable gromit was broken for a short period of time, the car would basicly not shift to a larger gear if you "floored it" but would slowly shift to the appropriate gears.
*braces for the impact*
Arterious is offline
post #2 of 27 (permalink) Old 08-30-2005, 01:36 AM
Fry Rice Specialist
Casper's Avatar
they are both totally different animal.
aod is control by cable and no electronics. aode and 4r70w is electronic control tranny. some people use the gearset from 4r70w into aod because of the gearing advantage but aod even with 4r70w gearset are still being control by cable/mechanical.
CarDomain Page
Casper is offline
post #3 of 27 (permalink) Old 08-30-2005, 02:02 AM Thread Starter
can my car be upgraded to the 4r70w?
post #4 of 27 (permalink) Old 08-30-2005, 02:01 PM
Fry Rice Specialist
Casper's Avatar
that i'll have to let the expert chime in. the 4r70w you can use is from v6 mustang and some of the trucks and i'm almost sure a custom length driveshaft is needed.
but how to control the tranny with your ecu i have no idea though.
wait till some expert chime in before you start buying stuff ok?
CarDomain Page
Casper is offline
post #5 of 27 (permalink) Old 08-30-2005, 02:23 PM Thread Starter
I ain't buying anything tomorrow far from that I just want to know what I can do to either A: improve my tranny or B: what GOOD tranny can I replace it with, with the least amount of work/pocket cost
post #6 of 27 (permalink) Old 08-30-2005, 02:59 PM
Boom.
Palmguy's Avatar
To use a 4R70W, you'd have to convert to a '94-95 Mustang GT or 5.0 Explorer EEC or use a standalone controller.
TCCoABAMFC - Founding Member
TCCoA Gun Club
Palmguy is offline
post #7 of 27 (permalink) Old 08-30-2005, 03:42 PM Thread Starter
would you reccomend doing it palmguy?
post #8 of 27 (permalink) Old 08-30-2005, 03:47 PM
Johnny Five is Alive
WkStill's Avatar
Send a message via AIM to WkStill Send a message via Yahoo to WkStill
Depends on how skilled you are.
I'm running a 4r on a 5.0 controlled by an aftermarket computer.
1984 Merc Cougar
5.0L, GT40X HEADS, E303 CAM,X303 Valvetrain
1998 4R70W Controlled by Baumannator TCS., 3.73 Track Lock Rear., Bauman Lev 3 Shift Kit.
190LPH, 67mm EGR, 65mm TB, 73mm C&L MAF, 24lb/h Inj, TwEECer RT, A3M EEC-IV
TCCoA-AHole Crew 2004
Disclaimer: The opinions expressed in my posts are my own. They are not meant to start a flame war or discourage people. Just my honest opinion and nothing more
Just great, 4 mores years of GOP crap, Im republican, and I endorse this message
WkStill is offline
post #9 of 27 (permalink) Old 08-30-2005, 03:49 PM
WkStill's Avatar
Note, Bauman now sells a harness for there computer..
http://www.becontrols.com/products/tcsfullharness.htm
1984 Merc Cougar
WkStill is offline
post #10 of 27 (permalink) Old 08-30-2005, 04:57 PM Thread Starter
how do you like it wkstil? works well? My knowledge is greatly lacking with cars. but I do have friends who are quite skilled.
post #11 of 27 (permalink) Old 08-31-2005, 07:50 AM
WkStill's Avatar
the TC lockup functions are "Lacking" but other than that the controller is very easy to work with. just make sure you adjust the line pressure settings with a gauge connected, this way you can be sure you don't fry the transmission.
1984 Merc Cougar
WkStill is offline
post #12 of 27 (permalink) Old 08-31-2005, 09:24 AM
I converted my 93 5.0 TBird to use a 4R70W. I'm using a 95 Mustang GT EEC. I am familiar with Baumann's software and there is no comparison to the level of control offered by the GT EEC. I guess it works, but it essentially turns a 4R70W into a very nice AOD. The EEC conversion is not hard - I don't remember all of the details.
Mitch
MitchB is offline
post #13 of 27 (permalink) Old 08-31-2005, 11:53 AM
The Great Obucina's Avatar
you could just rebuild your AOD and use the 4R70W gearset.
"Booyah". Stu Scott.
The Great Obucina is offline
post #14 of 27 (permalink) Old 09-03-2005, 08:05 AM
Johnny Bling Bling
93 lx's Avatar
or buy a rebuilt they are dirt cheap. i have seen some go for under $500 on ebay...with warranty. used one from a boneyard should only be about $100-$150.
2009 Ford Flex Limited AWD
93 lx is offline
post #15 of 27 (permalink) Old 09-03-2005, 08:15 AM
Johnny Bling Bling
93 lx's Avatar
http://forums.tccoa.com/showthread.php?t=64727
93 lx is offline
post #16 of 27 (permalink) Old 09-03-2005, 11:00 AM
It all depends on how much cash you want to spend. You could build a mild aod with a 4r70w gearset but the costs mount quickly when trying to make it durable.
The best bet would be a 4r70w with a custom stall converter, 94 stang computer and a chip to make it shift right. Or the baumann would be cheaper than a chip and computer swap + alot easier. Otherwise it might cost as much to upgrade an aod.
I have about $1100 dollars in my aod in parts alone!!!!! that's just plain crazy when I could've had a computer shift for me for that much dough.
I love my aod now but a lockup converter with a 4r70w would be nicer with gas prices like they are.
icantdrive55 is offline
post #17 of 27 (permalink) Old 09-03-2005, 11:03 AM
ABA
ABA's Avatar
What if any are the advantages in AODE over an AOD? The least amount of electronics the better I like it.
'93 T-Bird bone stock 3.8, 17" Cobra R rims and Bridgestone Potenza Tires.
Clear corners with Stealth bulbs, Audi style LEDs, Blacked Out Tails.
ABA is offline
post #18 of 27 (permalink) Old 09-03-2005, 12:49 PM
well.....and AODE is electronically controlled...and AOD aint.
post #19 of 27 (permalink) Old 09-03-2005, 04:18 PM
ABA
ABA's Avatar
DOH, is that what the E stands for? I thought it meant Extreme. So what are the advantages of an AODE over an AOD trans?
ABA is offline
post #20 of 27 (permalink) Old 09-05-2005, 10:51 PM
WkStill's Avatar
The AODE is an Early Model 4r70w..
So, its technically a WEEK 4r70w w/AOD Gearing..
Ford standerdized its Transmission Naming.
1984 Merc Cougar
WkStill is offline
post #21 of 27 (permalink) Old 09-06-2005, 01:33 PM
Fry Rice Specialist
Casper's Avatar
the e stands for electronic control.
CarDomain Page
Casper is offline
post #22 of 27 (permalink) Old 09-06-2005, 02:45 PM
ABA
ABA's Avatar
Is one better than the other one?
ABA is offline
post #23 of 27 (permalink) Old 09-06-2005, 03:17 PM
way off topic, but the new 2006 Crown Vic/Grand Marquis get a 4R75E, I know the 4 is forward gears, R is rear wheel drive, and the 75 is torque handling capabilities, but the E now stands for? It is sealed and has lifetime fluid
The 4R75E is an evolution of the 4R70E that is used in the current F-150. The biggest changes are a faster computer, redesigned toque converter, addition of a turbine-speed sensor, "smart" shift control unit, and a fully sealed case filled with lifetime transmission fluid.
Bangster is offline
post #24 of 27 (permalink) Old 09-06-2005, 08:10 PM
Well, the W in 4R70W meant that it has a wide-ratio gearset.
SloMo228 is offline
post #25 of 27 (permalink) Old 09-07-2005, 10:57 AM
maybe the E for Eternal?
ghostfield is offline
post #26 of 27 (permalink) Old 09-07-2005, 11:53 AM
I have no idea what it's supposed to stand for, but that's as good a guess as any!
SloMo228 is offline
post #27 of 27 (permalink) Old 09-07-2005, 10:39 PM
Fry Rice Specialist
Casper's Avatar
maybe the 4r75e is not wide gearset anymore?
CarDomain Page
Casper is offline
