4r70w on a 427 - TCCoA Forums
post #1 of 24 (permalink) Old 09-01-2005, 12:15 AM Thread Starter
4r70w on a 427
what do i have to do to make a 4r70w handle a 351 with a 427 stroker
MCthunderbird is offline
post #2 of 24 (permalink) Old 09-01-2005, 12:34 AM
seawalkersee's Avatar
Do a search for DIRTYDOG and ask him.
Chris
seawalkersee is offline
post #3 of 24 (permalink) Old 09-01-2005, 01:31 AM
The Great Obucina's Avatar
alan makes convertors, talk to Darrin, he makes the bulletproof 4R70Ws.
331>351.
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 24 (permalink) Old 09-01-2005, 04:38 AM
It's all in the tech article's guys
post #5 of 24 (permalink) Old 09-01-2005, 12:46 PM
See...told ya he would know.
Chris
post #6 of 24 (permalink) Old 09-01-2005, 01:52 PM Thread Starter
thanks
post #7 of 24 (permalink) Old 09-01-2005, 02:03 PM
Darrin's Avatar
Are you wanting to do this yourself or are you wanting a transmission built?
Darrin is offline
post #8 of 24 (permalink) Old 01-30-2006, 05:56 AM
do all the mods in the tech articles apply to say a 2004 4r70w?
cubes is offline
post #9 of 24 (permalink) Old 01-30-2006, 06:52 AM
Chapter Director Coordinator
jamesD's Avatar
the newer trans have slightly different valve bodies and most of the updated components as far as pistons, springs, servos, one-way mechanical clutch instead of the roller ****clutch, etc..
the 2004 4r70w is not a good option unless you feel like having the trans totally disassembled and the output shaft swapped for one that has provisions for a speedo gear
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #10 of 24 (permalink) Old 02-05-2006, 04:00 AM
not fussed on on using the stock speedo function as this is a custom install so an electronic speedo control is no prob, given that the later boxes have all the internal upgrades which is the better year to start with (I know this has been asked countless times before) also building a 427 and looking for a lockup trans that can handle 600 lb/ft torque (not in lockup of course) , sorry to hijack the thread.
The raeson for my oroginal question was that the tech articles were written a few years ago and there are more current 4r70w with improvements .
cubes is offline
post #11 of 24 (permalink) Old 02-05-2006, 12:03 PM
All of the tech articles are not up to date there is a newer design stub shaft and the 01 up valvebodies are better in my opinion.
post #12 of 24 (permalink) Old 02-05-2006, 01:15 PM
Stub Shaft?...That the outer one that goes to the converter?
Chris
post #13 of 24 (permalink) Old 02-05-2006, 01:43 PM
no the inner one that goes to the direct drum.
post #14 of 24 (permalink) Old 02-05-2006, 04:32 PM
terraplane8's Avatar
Outside of the AOD-E's that the 94-95 Mustang's had, and the 4R70W's the 3.8's got, do any of the electronically controlled passenger car trannies fit on a 351 block? Different gear ratios there, but I did the j-mod to my 94 GT, with no problems. I'm pretty sure my 94 SC had a 4R70W, but that was a bad year for them, IMHO.
Submariners do it deeper...
terraplane8 is offline
post #15 of 24 (permalink) Old 02-05-2006, 08:55 PM
Teeps's Avatar
Yeah, the 3.8 and 5.0 block / Transmissions will have the right bellhousings pattern, a 4.6 pattern is not correct.
1997 Sport - Work in progress:>
MP BB 304 Teksid 4v- w IC'd / Ported M112
Need:
Eaton pulley puller (VMP or BF preferred)
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #16 of 24 (permalink) Old 02-05-2006, 10:43 PM
Soooo...go with the 01 for a build up? Is it the 01 and newer or is it just an oddball year?
Chris
post #17 of 24 (permalink) Old 02-06-2006, 05:22 PM
jk69cat's Avatar
took the words right out of my mouth, i thought that he would have to use a newer v6 tranny to get the right bell
mn12 less!
jk69cat is offline
post #18 of 24 (permalink) Old 02-06-2006, 06:28 PM
Don't forget the 92 crown vic tranny with the 5.0 bell 4.6.
post #19 of 24 (permalink) Old 02-06-2006, 07:57 PM
The 4.2 V6 is the same bellhousing also. That one also has the maximum amount of clutches.
icantdrive55 is offline
post #20 of 24 (permalink) Old 02-07-2006, 11:31 AM
02 Explorer Pioneer
timb's Avatar
And if you want a newer core the 01 5.0 explorer uses the 4R70W
Birdless
timb is offline
post #21 of 24 (permalink) Old 02-08-2006, 09:42 AM
I have a 95 Mark 4.6, tranny that needs a rebuild. I am willing to try through the steps but am also willing to pick up a newer year tranny if required. My 4R70W has had the J-Mod both 1/2 & 2/3 with plate hole enlargement to 300hp. Did the Mods in the driveway, can these steps be done in the driveway too(hump the tranny to the cellar)? Or where is the best source/cost for a newer tranny? Any info appreciated. Thanks, Ed
big ed is offline
post #22 of 24 (permalink) Old 02-08-2006, 03:54 PM
Teeps's Avatar
cheaper to start with a newer reman or salvage trans as it has more of the parts already in it.
Need:
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #23 of 24 (permalink) Old 02-08-2006, 04:37 PM
Maybe I was not clear. Is the O1 the only one that uses the better parts? What is the BEST year to go with? I assume you can use any 01 and newer ones and SHOULD be okay as long as they have the provision for the gear on the output shaft. Then just repin and J-Mod right?
Chris
post #24 of 24 (permalink) Old 02-08-2006, 07:07 PM
03 up have the best parts excluding the fact the output shaft won't work.
