4r70w - TCCoA Forums
post #1 of 3 (permalink) Old 09-15-2005, 10:48 AM Thread Starter
tbirdtess's Avatar
Question 4r70w
Hello
I am getting a 1997 thunderbird. What transmission 4R70W?
If so can I race this transmission with-out a computer?
I race a circle track car. we run in second gear due to the gear rule. I have a 351w & a c4. Would like the 4R70W for the gear ratio advantage.
If it will work, can the overdrive be removed?
Or can the second gear cluster fit in my C4 or My FMX?
PAUL
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #2 of 3 (permalink) Old 09-15-2005, 11:22 AM
Send a message via AIM to Grand_Marquis_GT Send a message via Yahoo to Grand_Marquis_GT
The 4R70W interanls (not sure which ones) will fit in an AOD, i know that...
If you ran a C6, I hear E4OD internals work, for the same "wide ratio"
If your arm doesnt hurt, you aint shifting it hard enough!
1995 T-bird LX (Sharky) Third cat/muffler delete, 2200 stall, J-mod, Mechanical Diode, 3.27 trac-lock...
Cosmetic: Clear Corners, silverstar 3157s, Hoodpins, cheadlight covers...
Pros: Good on gas, faster than the merk at the moment
Cons: Multicolor paint.
1984 Grand Marquis "GT" Coupe 302 HO/Tremec 3550 swap in progress, suspension mods galore, and a killer stereo.
Pros: Comfortable, better stereo.
Cons: Sucks gas, slow (Till I get that motor in )
Grand_Marquis_GT is offline
post #3 of 3 (permalink) Old 09-15-2005, 11:52 AM
Johnny Five is Alive
WkStill's Avatar
Send a message via AIM to WkStill Send a message via Yahoo to WkStill
I am no expert, but if your running circle track. And you just want one gear, i would assume you could probably build a simple circuit to force full line pressure, and second gear ( or manual 2nd, which would give engine breaking) this solution probably would be simple, just watch the trans fluid temperature. You could probably even command a TC Lockup on strait aways. this would pretty much result in less tc slippage from not being engaged.
1984 Merc Cougar
5.0L, GT40X HEADS, E303 CAM,X303 Valvetrain
1998 4R70W Controlled by Baumannator TCS., 3.73 Track Lock Rear., Bauman Lev 3 Shift Kit.
190LPH, 67mm EGR, 65mm TB, 73mm C&L MAF, 24lb/h Inj, TwEECer RT, A3M EEC-IV
TCCoA-AHole Crew 2004
Disclaimer: The opinions expressed in my posts are my own. They are not meant to start a flame war or discourage people. Just my honest opinion and nothing more
Just great, 4 mores years of GOP crap, Im republican, and I endorse this message
WkStill is offline
