4R70W filter left out? - TCCoA Forums
post #1 of 19 (permalink) Old 10-25-2005, 03:12 PM Thread Starter
This might be a dumb Q but maybe someone has an aswer ...
If the tranny filter was left out by mistake and tranny was filled. Would it shift at all / shift properly?
(2001 GrandMarquis 4R70W Tranny going into 98 Towncar)
tutuluke is offline
post #2 of 19 (permalink) Old 10-25-2005, 03:25 PM
Whining Intakes Rock
Al_Florida's Avatar
For a little while.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 19 (permalink) Old 10-25-2005, 04:06 PM
Originally Posted by Al_Florida
For a little while.
You sure? Doesn't the filter act as a sort of pickup tube too?
Sometimes, we just need to remember what the rules of life really are:
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
doodaa is offline
post #4 of 19 (permalink) Old 10-25-2005, 04:24 PM
Al_Florida's Avatar
It does.
# 0 rows returned
post #5 of 19 (permalink) Old 10-25-2005, 04:24 PM
I have never left it off so I don't know what it would do, but I would imagine it wouldn't do much of anything unless it was over filled. I could see problems with leaving in the old O-Ring (not really an O-Ring) or using the wrong filter (for the shallower pan) causing problems. I know that a co workers car was pretty bad off when the service place left the old seal in place and the filter sucked air around where the filter should seal.
Bangster is offline
post #6 of 19 (permalink) Old 10-25-2005, 05:38 PM
It would work provided there was enough fluid in the pan to reach the pickup (for a little while anyway), plus any debris in the fluid would likely [email protected]#$! up the tranny too.
SloMo228 is offline
post #7 of 19 (permalink) Old 10-25-2005, 05:49 PM
Al_Florida's Avatar
# 0 rows returned
post #8 of 19 (permalink) Old 10-26-2005, 06:49 PM
J.Miller's Avatar
Come on guy... Go buy a filter and put it in your car. You can ruin your transmission with out a filter.
J.Miller
East Coast Rolling Thunder!!!!
Official Eastern and Central PA chapter of the SCCoA!
J.Miller is offline
post #9 of 19 (permalink) Old 10-26-2005, 07:17 PM
wilson502's Avatar
just like u would ruin an engine running it without an air filter.
2007 White Ford Focus SE ZX3 Hatchback (The new driver)
1997 Alpine Green 4.6L Bird (SOLD!)
Mods:
Removed Air silencer, Clear Corners, Silverstar headlights and corner lights, Moroso Bluemax Spiral Core wires, Custom 3" Magnaflow exhaust with 2.5" Y-Pipe, 300-450 HP J-mod Kit by dirtyd0g , Hayden 30k GVWR Trans Cooler, Sport Front Suspension, 03-04 Cobra Rear Shocks, PBR Front Brake Swap, Xcal 2 by Lonnie @ Blueovalchips.com, 22C plugs, 180F T-stat, 02GT MAF/Airbox with K&N Drop in, Griffin Radiator, Cobra Water Pump
wilson502 is offline
post #10 of 19 (permalink) Old 10-27-2005, 07:21 AM Thread Starter
Ofcourse that's what I plan to do this weekend - thanks for all the inputs.
tutuluke is offline
post #11 of 19 (permalink) Old 10-27-2005, 08:20 AM
man I almost did that... I was bolting the pan up and i got up to get my torque wrench and saw the thing sitting there in the cloth and was like aww crap... had to unbolt it all and do it over again LOL..
FunktasticLucky is offline
post #12 of 19 (permalink) Old 10-31-2005, 11:08 AM Thread Starter
If you leave the filter out of 4r70W (as I did) - here is what it does - 1-2 shift is not smooth- delayed and rest of the shifts were fine. New filter is in place now and works like a charm.
Thought I post this for anyone else who would do the stupid mistake I did!
tutuluke is offline
post #13 of 19 (permalink) Old 10-31-2005, 12:56 PM
95tbirdguy's Avatar
Would that make it not shift from 2nd to 3rd at a high rpm?
95tbirdguy is offline
post #14 of 19 (permalink) Old 10-31-2005, 01:00 PM
Traveler's Avatar
Its very difficult to put a filter in when the seal from the old filter is still there. It just doesn't fit right, prompting a cautious person to look and see why it isn't fitting right. Upon observation, you'd see the problem, remove the old seal, and install the new filter easily.
I know this because I tried to install one filter with two seals.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #15 of 19 (permalink) Old 10-31-2005, 01:00 PM Thread Starter
No - 2-3 shift was almost normal ... 1-2 was the worst - 3-4 was almost normal as well ... its not that the RPM soared and then it shifted.
tutuluke is offline
post #16 of 19 (permalink) Old 11-01-2005, 07:26 AM
95tbirdguy's Avatar
when i am accelerating hard i have to let my for off of the gas to make it shift from 2nd to 3rd. that is why i was asking. it has been like that ever since the tranny was rebuilt. i am just curious though cause i am getting ready to do a t45 swap. so it really doesn't matter lol
post #17 of 19 (permalink) Old 11-01-2005, 08:13 AM
dude... I would have taken it back to the shop and raised hell... spend that much money on a rebuild and that kiinda crap is goin on. When i got my C4 rebuilt I took it home and came out 2 hours later to go somewhere and there was tranny fluid on teh ground... WTF... yeah it went right back to the shop. Keep my car for 3 weeks and then when I get it back tranny fluid is on the ground. Thats rediculous.
post #18 of 19 (permalink) Old 11-02-2005, 09:05 PM
95tbirdguy's Avatar
Well no lol this is funny. i took it in and had it rebuild. cost me like 800.00. it did fine for a month and a half then crapped out on me. i took it back and they had it for 6 months before they got it fixed so it would even shift. i was soo pissed. i went back to get it fixed again and the dang shop was closed.
post #19 of 19 (permalink) Old 11-02-2005, 09:52 PM
yeah there is a reason they were closed... shawdy work perhaps... I would say go with Darrin's tranny right now... you'll never have to worry about it again. that would be a tranny you take out and move to your new car cuz it won't ever die
post #20 of 19 (permalink) Old 11-03-2005, 11:43 PM
95tbirdguy's Avatar
Lmao. I am doing a t45 swap. i love a 5 speed.
