4R70W/MLP issues - TCCoA Forums
post #1 of 6 (permalink) Old 11-01-2005, 08:56 AM Thread Starter
4R70W/MLP issues
My father has a 1994 Thunderbird with the 4.6L engine and 4R70W tranny. For the last couple of years he has had problems associated with a bad MLP (gear searching, etc). Thanks to this forum, I not only found that the problem was likely the MLP, but found a NAPA part # for a cheap alternative to the Ford part. During all of his problems, he never the the check engine light come on. I know that a DTC can be set without making the lamp come on, but I am pretty sure that I had hooked up my OBDII computer to his car a year or so back and there were no DTCs. Anyway, he replaced the MLP with a new one from NAPA. His shifting problems immediately went away and the transmission was working flawlessly. However the check engine light came on immediately and the DTC was "0708 MLP circuit high". We cleared the code and it came right back. I know that the MLP houses the circuits that only allow the ignition system to start the car when it is in PARK or NEUTRAL, and also to allow the backup lights to come on in REVERSE. All of these functions are working properly. What could be causing this DTC if everything is working properly? We are going to check the MLP voltages with my OBDII computer this weekend and then pull the new MLP and check the resistances between pins 2 & 3 in different lever positions. Thanks for any suggestions.
lemmy999 is offline
post #2 of 6 (permalink) Old 11-01-2005, 05:07 PM
Whining Intakes Rock
Al_Florida's Avatar
Did you get the MLPS for your year car?
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #3 of 6 (permalink) Old 11-01-2005, 07:00 PM Thread Starter
I got the part number off of this forum, but I just asked the NAPA guy for the MLPS for a 1994 T-bird 4.6L 4R70W and the part numbers matched. The Ford manual keeps referring to an MLPS alignment tool. Is this really necessary? I just thought you put the car in Neutral, take the old one off and bolt the new one up.
lemmy999 is offline
post #4 of 6 (permalink) Old 11-01-2005, 07:22 PM
02 Explorer Pioneer
timb's Avatar
I didn't use the alingment tool
Birdless
timb is offline
post #5 of 6 (permalink) Old 11-01-2005, 09:24 PM
Al_Florida's Avatar
There are a couple of lines on the MLPS that you line up when you install it. I don't have a better pic at the moment so I'll use this one. The lines are where the green arrow points.
# 0 rows returned
post #6 of 6 (permalink) Old 11-02-2005, 06:53 PM Thread Starter
We pulled the new one off and the impedance was always high no matter the setting. We took it back to NAPA and got another one and it works fine and the light is off. Thanks for the help.
lemmy999 is offline
