Can A 4R70W Stay in 1st and 2nd longer..? - TCCoA Forums
post #1 of 6 (permalink) Old 11-11-2005, 08:54 PM Thread Starter
I did a search, and i found mostly engine tuning/timing etc.
What would i have to do to basically make 1st shift MUCH later at slow speeds, the same with 2nd..? Mainly so that i can stay in 1st like a manual. I hate it how my car shifts 1,2,3,OD in like 6 seconds and i'm doing 36mph in 4th. This i understand is for fuel economy, but i much rather have 1st up to like 28mph whether i'm easy on the throttle of full on WOT.
Would a speed shop be able to do this..? I don't think anything else would have to be changed either, like a/f, timing etc.
snow is offline
post #2 of 6 (permalink) Old 11-11-2005, 08:56 PM Thread Starter
-I don't, and do not want to shift manually like 1, 2, D, OD etc.
snow is offline
post #3 of 6 (permalink) Old 11-11-2005, 09:16 PM
Talk to Lonnie at Blue Oval, mine shifts much later although not 28 mph, more like 20 ish.
Dave
davesxx01 is offline
post #4 of 6 (permalink) Old 11-11-2005, 09:33 PM
yup the only way you can really change the shift schedule is with a chip or tuner which lonnie is the man at
MattsLE97 is offline
post #5 of 6 (permalink) Old 11-11-2005, 09:47 PM
VicRattlehead's Avatar
i believe you can have the shift set to either rpm or vehicle speed. so you can program it to shift whenever you want. order a chip from lonnie. (see my sig)
CMP Drag Racing
VicRattlehead is offline
post #6 of 6 (permalink) Old 11-11-2005, 09:51 PM Thread Starter
It's good to know this can be done, thanks guys..i'll check out lonnie.
snow is offline
