98 4r70w - TCCoA Forums
post #1 of 8 (permalink) Old 01-27-2006, 04:21 PM Thread Starter
98 4r70w
my trans is shot, will a 1998 4R70W out of a mustang GT work on my car? if so what do i have to change, or is it a bolt over setup?
94V8Thunderbird is offline
post #2 of 8 (permalink) Old 01-27-2006, 05:01 PM
The Great Obucina's Avatar
yes it will. You need to swap over some small parts, but it will fit. Its got the good parts also.....do an el searcho... the tech articles have everything you need to know
"Booyah". Stu Scott.
The Great Obucina is offline
post #3 of 8 (permalink) Old 01-27-2006, 05:15 PM
Whining Intakes Rock
Al_Florida's Avatar
99+ has a better valve body.
# 0 rows returned
# drop table users;_
Al_Florida is offline
post #4 of 8 (permalink) Old 01-28-2006, 03:10 PM Thread Starter
its a 98 GT trans, what little parts do i need to swap? and what should i do a search for? and if the tailshafts are two different lengths, can i use my tailshaft on that transmission?
post #5 of 8 (permalink) Old 01-28-2006, 03:22 PM
Darrin's Avatar
You need to swap the manual lever on the side of the transmission from yours to the new tranny. Then you need to repin the harness in your car to work with the newer style electronics, and get the proper TCC solenoid for your car. You will also need to get a speedometer gear that will correct for the 8 tooth VSS drive gear on the output shaft. You car has a 7 tooth drive gear and the speedometer will be off with that transmission and your gear.
I think thats all. I have been in computer hell with upgrades and moving my computer. So if I forgot anything, I am sure someone else will chime in.
Good luck with it
Darrin
Darrin is offline
post #6 of 8 (permalink) Old 01-28-2006, 03:25 PM Thread Starter
http://cgi.ebay.com/ebaymotors/MEGA-...QQcmdZViewItem
you guys think this is a good trans for my car for the price?
post #7 of 8 (permalink) Old 01-28-2006, 09:11 PM
I think that transmission is a crock of crap. A stock unit is better. Modified OD my butt, 4 plate intermediate instead of 3...not in a 4r70w they had 4 anyway. Gaybestos frictions...I'd rather have the real high carbon (dynax) ford frictions than that crap.
post #8 of 8 (permalink) Old 01-28-2006, 11:53 PM
Allison had big problems with their HD B400 & B500 fleet transmissions. Initially built using raybestos clucthes, they later switches to dynax. Unless the raybestos units were serviced at 1/4 of the intervals spec'd by warranty, they all failed. These trans' use a control strategy that compensates for clutch wear. The ECM initiates the shifts earler and earlier as the clutches wear so until you get to the point where you literally have no clutches left, the trans performs normally with no sign of anything wrong. Allison sold these units to a multitude of over the road trucks and buses and this has been a very big warranty issue costing customers many thousands of dollars per unit. Working for the NYC transit authority and with the large number - 4000 or so units in service, we had enough leverage to force Allison to give us their software that allows you to see how much the ECM is compensating for clutch wear. This is essentially an electronic model of current clutch condition. We use this to monitor our units and before thry fail, we send them to Allison where they upgrade the units to dynax. This is done under warranty and is done for no one else. Other transit outfits throughout the country have asked us for this software, but legally we cannot give this out. Everyone has had problems with these units.
Err, excuse me for the diversion...
Mitch
MitchB is offline
