AODE -> 4R70W swap - TCCoA Forums
post #1 of 4 (permalink) Old 03-22-2006, 12:19 PM Thread Starter
AODE -> 4R70W swap
For 94/95 Mustang
what do I need to make this swap happen?
97 or older should wire dirrectly up correct? IS it the same plug-n-play?
Will I have to change the computer to control the new shift points?
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #2 of 4 (permalink) Old 03-23-2006, 03:53 PM
Like Titles Matter
kdanner's Avatar
Originally Posted by SilverFox
For 94/95 Mustang
You'll need a new slip yoke unless you want to use the AODE tailhousing. 97 and older works yes, but they are junk. Best to repin your harness and use something newer. Yes, you'll need a tune.
1998 GT - [email protected]
generated by sloganizer.net
kdanner is offline
post #3 of 4 (permalink) Old 03-23-2006, 03:57 PM Thread Starter
Thanks....Swaping Ext Housings would probably prove less effort than a yolk swap. Thanks for the info, the tune is the crappy part - but well worth it I am sure.
post #4 of 4 (permalink) Old 03-29-2006, 03:27 PM
I'm doing this swap, was wondering if anyone had any part # recommendations on U-joints, going with a transbrake and don't want to break em.
davidl340 is offline
