98 4r70w stuck in 2nd - TCCoA Forums
post #1 of 7 (permalink) Old 05-02-2006, 10:52 PM Thread Starter
a few days ago i put in a transgo shift kit in my 98 f 150 4.6 went to drive it and it starts off in 2nd and wont come out of 2nd. took it apart agian clean everything made sure i did it right still does the same thing. what would make it stay in 2nd? also the connection that goes though the trans to a black strip that goes across the valvebody to the shift solnoeds i broke the clip that holds the connection togather.
the next day i cleaned all the electronics put dielectric grease on the connections and replaced the clip i broke still the same thing.
when you have the valvebody out sould you here something in the solenoids moving when you tip it back and forth? could i have messed up something in the valve body to make it do this?
when i was putting in the 1-2 and 2-3 shift valves i had to push very hard to get them in could this be the problem? do you think getting the factory tech will fix my problem?
i know this isnt a ford truck site but i was told yall were the kings of the 4r70w
thanks
matt_svt is offline
post #2 of 7 (permalink) Old 05-03-2006, 12:16 AM
Fry Rice Specialist
Casper's Avatar
well, you put that trans-blow kit in there, that may explain some of the problem. i forgot what's the exact detail on that trans-blow kit but some other may chime in.
i take that you torque the valvebody down 3 times 1 after each sequence to make sure there's no cross leak right?
the accumulator hard to put it in i remember 1 of mine is hard to put it in because of the spring force but another one is very easy. check if the bore has scored mark and if it does, use some greenpads sponge to smooth it out. before put the accumulator piston in lube the piston's lips with some tranny fluid as lubrication.
the rest will have to let expert to chime in.
CarDomain Page
Casper is offline
post #3 of 7 (permalink) Old 05-03-2006, 07:18 AM
You need a whole valvebody now. You cannot install a factory tech plate kit on a trans-go ruined valvebody. The core may not be acceptable either you'll have to ask Gregg on that one. Stuck in second means the transmission has a code you need to find out what that code is.
post #4 of 7 (permalink) Old 05-03-2006, 09:45 AM
Darrin's Avatar
The trans go was a bad idea, but you broke or messed something up in the electronics. 2nd is the limp home mode of the trans and thats what you get when the electronics are not functioning.
Time to get out a volt ohm meter and follow the diagnostics to check continuity for all the components.
Darrin
Darrin is offline
post #5 of 7 (permalink) Old 05-03-2006, 11:41 PM Thread Starter
i thought that the factory tech was a whole new valve body. do yall have his email so i can ask him about sending in my old one as core?
matt_svt is offline
post #6 of 7 (permalink) Old 05-04-2006, 01:06 AM
Factory Tech is selling a plate kit now for the later transmissions. It is a much cheaper way of doing the same thing excluding pre96 transmissions. He does offer a complete valvebody his Email is Gregg at factorytech dot net I think I will have to check my Factory Tech email to be sure.
post #7 of 7 (permalink) Old 05-04-2006, 08:21 AM
02 Explorer Pioneer
timb's Avatar
Second is the limp home mode but is it possible he reinstalled with the detent switch in the wrong possition so it's selecting second when in drive?
Birdless
timb is offline
