AODE and 4R70W gearset ratio - TCCoA Forums
post #1 of 3 (permalink) Old 06-14-2006, 11:48 AM Thread Starter
Whining Intakes Rock
Al_Florida's Avatar
Ratios of the planetary gearset on the AODE and 4R70W transmissions:
AODE
2.00:1 in reverse
2.40:1 in 1st gear
1.47:1 in 2nd gear
1.00:1 in 3rd gear
0.67:1 in 4th gear (overdrive)
4R70W
2.32:1 in reverse
2.84:1 in 1st gear
1.55:1 in 2nd gear
1.00:1 in 3rd gear
0.70:1 in 4th gear (overdrive)
(for future searches)
Al_Florida is offline
post #2 of 3 (permalink) Old 06-14-2006, 09:54 PM
I will add the ratios for the manual transmissions as well
The 89-93 M5RD ratios are
5th (0.75)
4th (1.00)
3rd (1.43)
2nd (2.32)
1st (3.75)
The 94-95 ratios are
5th (0.75)
4th (1.00)
3rd (1.34)
2nd (2.16)
1st (3.42)
post #3 of 3 (permalink) Old 06-16-2006, 12:07 AM
Refrigerator Raider Hater
GreenBird's Avatar
Ford Motor Company Transmission Gear Ratio's
Rear Wheel Drive Automatic Transmissions
Five Speed Automatic Transmissions
1st 2nd 3rd 4th 5th
Trans Gear Gear Gear Gear Gear
Model Ratio Ratio Ratio Ratio Ratio
A5LDE 2.47 1.87 1.47 1.00 0.75
5R55E 2.47 1.87 1.47 1.00 0.75
5R55N 3.25 2.44 1.55 1.00 0.75
5R55W 3.22 2.41 1.55 1.00 0.75
Four Speed Automatic Transmissions
1st 2nd 3rd 4th
4R44E 2.47 1.47 1.00 0.75
4R55E 2.47 1.47 1.00 0.75
4R70W 2.84 1.55 1.00 0.70
4R100 2.71 1.54 1.00 0.71
AOD 2.40 1.47 1.00 0.67
AOD-E 2.40 1.47 1.00 0.67
A4LDE 2.47 1.47 1.00 0.75
A4LD 2.47 1.47 1.00 0.75
E4OD 2.71 1.54 1.00 0.71
Three Speed Automatic Transmissions
1st 2nd 3rd
C4 2.46 1.46 1.00
C5 2.46 1.46 1.00
C6 2.46 1.46 1.00
Ford Rear Wheel Drive Manual Transmissions
Six Speed Manual Transmissions
1st 2nd 3rd 4th 5th 6th
Trans Gear Gear Gear Gear Gear Gear
Model Ratio Ratio Ratio Ratio Ratio Ratio
M6HD-6 5.79 3.31 2.10 1.31 1.00 0.72
Tremec T56 2.90 2.07 1.43 1.00 0.84 0.57
Five Speed Manual Transmissions
1st 2nd 3rd 4th 5th
T45 3.37 1.99 1.33 1.00 0.67
T5OD 1992-1998 3.35 1.93 1.29 1.00 0.78
T5OD 1999-2003 3.35 1.99 1.33 1.00 0.68
TR3650 ???????????
M5OD 3.97 2.34 1.46 1.00 0.79 (Mustang 2.3L)
M5OD 3.35 1.93 1.29 1.00 0.68 (85-88.5 5.0L)
M5OD 3.35 1.99 1.33 1.00 0.68 (88.5-93 5.0L)
M5OD-R1 3.72 2.20 1.50 1.00 0.79 (2.3L, 3.0L Engines)
M5OD-R1 3.40 2.05 1.31 1.00 0.79 (4.0L Engine)
M5OD-R1HD 3.40 2.05 1.31 1.00 0.79
M5OD-R2 3.91 2.24 1.49 1.00 0.80
M5OD-R4 3.38 2.06 1.30 1.00 0.79
M5HD 4.14 2.37 1.42 1.00 0.77 (Close Ratio - Diesel)
M5HD-W 5.72 2.94 1.61 1.00 0.76 (Wide Ratio - Gasoline)
M5R2 3.75 2.32 1.43 1.00 0.75
M5R2-C ??????????
M5-221 ??????????
Four Speed Manual Transmissions
1st 2nd 3rd 4th
T18 6.32 3.09 1.69 1.00
T18-A 6.32 3.09 1.69 1.00
T19 5.11 3.03 1.79 1.00
T-176 3.52 2.27 1.46 1.00
T199 Send us the gear ratios
TR-3340 Send us the gear ratios
NP435 6.69 3.34 1.79 1.00
Source: Ford 1997-2000 Powertrain Service Engineering Product Guide, Ford 1992-2003 Service Manuals
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
