For what it's worth, 4R70W rebiuld - TCCoA Forums
post #1 of 4 (permalink) Old 07-20-2006, 11:19 AM Thread Starter
Working on my bro-in-laws 99 GT mustang, everything was going well. He and I decided to tackle this ourselves because it was slipping a little (80K), so maybe we could get away with a rebuild kit and some misc parts and a good inspection. We bought a stock reman T/C ($219) and a master Alto rebuild kit ($300), a 5.4L truck pressure solinoid, stock OD & Rev bands. When it came time to do the seals for the tailshaft, I decided to go with factory cast iron seals, the front one was real bad, worn down and the latch tab was "gone". Looking in the back bore of the case it was apparent that just replacing the seals was nowhere good enough. The bore was trashed where the seal hits it (.015"). So, having a machine shop, I hung it off the table of the Bridgeport and bored it .125" oversized and turned up a press-in sleeve. Deep hole drilled the ports back in. This is not a normal wear surface, the seal is supposed to remain atleast somewhat stationary. The shaft looks fine, maybe a little (.002") wider, but smooth. It was good to find out what the problem was though. We'll be doing a flush and new cooler also.
One reason I'm posting this is because alot of people trash rebuilders (which I'm not) and mechanics when the cost of a quoted repair has "surprizes" once the job is started. Some sh** is unavoidable. Most, if not all, repair shops have no way to fix this type of problem, or even know about it in advance. I don't know how much a replacement case is, but I'm sure it would add significantly to the cost, and completion time.
Thoughts and comments welcome.
11.18 @ 128
list of Mods
DanCobra96 is offline
post #2 of 4 (permalink) Old 07-20-2006, 01:35 PM
I fresh shinny new case is a dream to work with - but the bore and sleeve (they sell that you know) is far cheaper I am sure.
I hope you replaced the case bushing at the bottom also - bet it is ugly as well.
You make a good point about pricing....and have been caught before quoting complete without tearing apart......though I am usually not that bad off, I have started tearing down BEFORE I quote. In the end this is a win win, cause sometimes you find very nice things already there and save a few bucks - the customer always likes that.
www.Silverfoxtrans.com
www.clickclickracing.com
SilverFox is offline
post #3 of 4 (permalink) Old 07-20-2006, 06:57 PM Thread Starter
If you mean the bronze sleeve, it was fine. The bore is only used to seal the feed holes to the tailshaft. So I think we're good to go.
11.18 @ 128
list of Mods
post #4 of 4 (permalink) Old 07-21-2006, 05:58 AM
If I e-mailed you my tranny would you tear mine down and rebuild it for me?
foobarbigtime is offline
