4R70W + transgo (problem?) - TCCoA Forums
post #1 of 14 (permalink) Old 08-12-2006, 08:49 PM Thread Starter
ajm
Today I installed a transgo shift kit in my 99 f150 w/ 4R70W transmission. All went well, no problems taking it apart putting it together etc. When driving it it seems as if I can only catch gears if I physically shift it (1-2-D) once in D when im goin about 50-60 and give it gas it sounds like it just revs from 1000-3500 rpm then itll actually move. Is this normal or does anyone have an idea as to whats up/what I did wrong.
ajm is offline
post #2 of 14 (permalink) Old 08-12-2006, 09:02 PM
You installed a transgo thats what you did wrong, sorry to be rude blunt is all I have.
post #3 of 14 (permalink) Old 08-12-2006, 09:25 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Sorry dude-you now need a new VB-transgo ruined yours.
JL
Fuelly
Johnny Langton is offline
post #4 of 14 (permalink) Old 08-12-2006, 09:42 PM
Darrin's Avatar
Aw hell, I guess I should jump on the wagon.
We sincerely regret to inform you...
No really, that trans-go thing, it was a bad idea. Both of the above are correct. A valve body transplant is likely the only real option at this point.
Sorry to be the bearer of bad news. That kit works fine for some, poorly for most and not at all for many. It is not removable. Its permanent and often fatal.
My condolences.
Darrin
Darrin is offline
post #5 of 14 (permalink) Old 08-12-2006, 09:55 PM
3rd Gear Chirper
hotbird's Avatar
Yup, the above statements are correct. I used to have a Trans-blow and it worked alright...but having the J-mod is so much better. Follow this link, read everything in the first 3 articles, including the instructions for the shift kit.
I will say this-if you didn't correctly torque your valve body bolts to 90 in-lbs then you can have crossleaks that will cause those symptoms. Recheck the bolts and plan on purchasing a new valve body soon. Then do the previously-mentioned J-mod instead.
hotbird is offline
post #6 of 14 (permalink) Old 08-12-2006, 10:27 PM Thread Starter
ajm
Very interesting to come here and see how everyone says that this kit is so bad (not being a smartass). All other info ive read people seem to be all over it but have no supporting info. Just curious but why do you guys keep mentioning a new valve body? Im guessing these kits have a tendency to screw them up?
ajm is offline
post #7 of 14 (permalink) Old 08-12-2006, 10:40 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
The Trans-Go kit makes modifications to the VB that cannot be undone. That is why you need a new one.
TGJ is offline
post #8 of 14 (permalink) Old 08-12-2006, 10:43 PM Thread Starter
ajm
Sounds like fun. Tomorrow im going to pull it apart again and make sure its not a stuck valve or something and make sure the bolts are torqued right. If it keeps on I guess a new valve body it is . After driving it more after making this post it seems like I only have 1st and 2nd gear. I can physically shift to the both of them but once I shift from 2 - D it makes no difference in rpm/cant feel a shift/nothing. Then when I shift back down to 2nd (same speed/rpm) I get the same results.
Seems like you guys need to go over to ford-trucks.com and show them how pathetic this kit really is.
ajm is offline
post #9 of 14 (permalink) Old 08-12-2006, 11:03 PM
well if u have to get a new vb get it jmodded you will like it much better
MattsLE97 is offline
post #10 of 14 (permalink) Old 08-12-2006, 11:07 PM Thread Starter
ajm
You guys happen to know what makes them work so poorly? Design? Effectiveness? Etc
ajm is offline
post #11 of 14 (permalink) Old 08-12-2006, 11:29 PM
Do not J-mod a truck valvebody. The plates are not the same. I don't know what holes get modified in the truck valvebody but I can get you a seperator plate for it. At this point you might as well get a car valvebody so you can j-mod it the transgo kit damages the valvebody core.
post #12 of 14 (permalink) Old 08-12-2006, 11:31 PM
ooops lol sorry for the wrong suggestion
post #13 of 14 (permalink) Old 08-13-2006, 09:59 AM
95xbird's Avatar
Has anyone told him to check his MLPS???Maybe it is out of its place causeing the truck not to shift right.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #14 of 14 (permalink) Old 08-13-2006, 11:50 AM Thread Starter
ajm
I took everything apart and put it back together. Still no luck. Although the revving problem isnt as bad.
ajm is offline
