4r70w bolts - TCCoA Forums
post #1 of 3 (permalink) Old 09-20-2006, 07:35 AM Thread Starter
4.3Lcougar's Avatar
4r70w bolts
does anyone know what size bolts are on the shift lingage bracket for a 4r70w transmission. i believe there are three. i did a tranny swap a while back and everything is good except these bolts. i put in three new bolts but they are threaded in all the way and keep freespinning if you try to tighten them up more...it remains in place but is very loose
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #2 of 3 (permalink) Old 10-22-2006, 01:33 PM
ummm if you are talking about that little bolt that you hook the cable to that goes to the shift arm... its supposed to be kinda loose. Its to allow the bolt to spin when you tighten the linkage up. that way as the arm moves back and forth it doesn't try to spin the cable... the cable stays pretty much horizontal. If that makes any sense.
FunktasticLucky is offline
post #3 of 3 (permalink) Old 10-23-2006, 09:25 PM
Over to Drive Train!
