4R70W questions.. no 1st or 4th. MLPS? - TCCoA Forums
post #1 of 6 (permalink) Old 11-10-2006, 12:46 AM Thread Starter
The_Ghost's Avatar
I have a 4R70W that is not using 1st and 4th gear, and stopped using them after a car-wash with the undercarriage wash.
I have another 4R70W tht behaved similarly when the MLPS was wayyyyyy out of whack (I have since re-adjusted it and 1st and 4th gears came back)
It is obviously some kind of electrical issue, what could possibly get wet that would make the trans start ignoring 1st and 4th gears?
Just trying to do some investigating and figure out what's going on.
Ghost
96 Laser Red 4.6L - Custom
Custom Nascar-Inspired Bodykit - 55* Rear Spoiler - J-modded Trans - 80mm MAF - One-Off Diablosport Chipmaster Revolution Chip/Tune W/Toggle - ScanGaugeII Diagnostics & Data Readout - PBR Brakes - Drilled/Slotted Rotors - SC Wheels & Springs - Falken Tires - KYB GR-1 Shocks/Struts - FSTB - RSTB - RTLB - LECB - 60/40 Split Rear - SC Seats - SC Vac/Boost Gauge
The_Ghost is offline
post #2 of 6 (permalink) Old 11-10-2006, 01:01 AM
Banned
-Check Solenoids (Check)
-Check MLPS (Check)
-Check ECU? (Check)
-Check Internal Wiring for tranny (Check)
-Check External Wiring for tranny *Not checked*
-Check External Connections *Not checked*
Those are all the things i can come up with. try searching as its my best friend here
Also got check engine light P0750 which is shift solenoid 1 malfunction. Ive replaced the solenoid and have made lots of people here clueless
Porkchop is offline
post #3 of 6 (permalink) Old 11-10-2006, 01:13 AM Thread Starter
The_Ghost's Avatar
8)
yeah, I'm trying to troubleshoot with what I know could make it behave like it is.
It'd be really sweet to have 1st lol.
I'm pretty sure the MLPS is probably doing it, since I really didn't see a whole hell of a lot coming off the tranny, but then again I cant really see the top of it, I can only see the sides.
The problem with search is that it's difficult to find something relevant to the observed symptoms and wording your symptoms correctly so that it yields a result.
I generally check the FAQ, read a few associated threads and if I dont find anything relevant I make a post to try to figure it out. I think I might dig into the Hayne's manual but I really think a Ford FSM would be worth a ton.
post #4 of 6 (permalink) Old 11-10-2006, 01:31 AM
Banned
Porkchop is offline
post #5 of 6 (permalink) Old 11-10-2006, 01:41 PM Thread Starter
The_Ghost's Avatar
McRoxor
2nd gear poster. w00t.
where are the transmission connectors?
post #6 of 6 (permalink) Old 11-15-2006, 07:43 AM
wether's Avatar
The external transmission wiring harness connector is located on the driver's side of the transmission cross member. . . . Is that the connector that you are looking for? The Transmission connector (connecting external wiring harness to the internal wiring harness) is located on the passenger side rear of the transmission it that corner of the transmission pan, but on "top". . . .the plug points down into the transmission and the connector is usually white unless it is covered with grease or something.
wether is offline
