4r70w swap into coupe - TCCoA Forums
post #1 of 23 (permalink) Old 03-30-2007, 10:04 PM Thread Starter
First off this is a question about swapping a 4r70w into my 93 5.0 mustang. Please don't hate, I also got a 86 tbird, but this is the only site that seems to know what there talking about on the 4r70w. I have bauminator for a 97-older 4r70w I have a 94 aode that I'm going to steal for the necessary sensors swap for the bauman to work with a 98-up trans. I'm bewteen using a 3.8 from a 99-up mustang or just getting a 4r70w from a 2000-up 4.2 f150 sense there about the same size. Does the 4.2 need any changes besides the tailshat swapped? Does anyone have the software that comes with the bauminator? The guy I can get one from cheap had a shop do a tune and ended up screwing him and they still have the software and we can't get it back. Thanks for helping a mustang. Matt
black93lx is offline
post #2 of 23 (permalink) Old 03-31-2007, 09:41 AM
4r70w wont bolt to a 5.0 bellhousing will it?
sleepinggt is offline
post #3 of 23 (permalink) Old 03-31-2007, 09:54 AM Thread Starter
yeah the 3.8 & 4.2 will, the 4.6 and 5.4 won't
post #4 of 23 (permalink) Old 03-31-2007, 09:54 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
That's why he is talking about using a 4R from a V6. Since a V8 tranny will be better (unless you are rebuilding anyway) you can use one from an Explorer 5.0. I am not sure what year they started using the 4R though.
tinman_72 is offline
post #5 of 23 (permalink) Old 03-31-2007, 09:25 PM
svtbird88's Avatar
all 5.0 explorer/moutaineers should have 4r70ws.
svtbird88 is offline
post #6 of 23 (permalink) Old 03-31-2007, 11:58 PM Thread Starter
yeah but its easier to find one from a 4.2 which is just as strong as the 5.0 explorers which are much harder to find.
post #7 of 23 (permalink) Old 04-01-2007, 12:08 AM
The Great Obucina's Avatar
i just found 9 pages of exploder 5.0 4R70W listings on car-part.com.....
"Booyah". Stu Scott.
The Great Obucina is offline
post #8 of 23 (permalink) Old 04-01-2007, 12:13 AM Thread Starter
yeah me too but most of them have alot more miles on them and cost more.
post #9 of 23 (permalink) Old 04-01-2007, 12:35 AM
suit yourself
post #10 of 23 (permalink) Old 04-01-2007, 09:15 AM Thread Starter
the 4.2 is just as strong as the 5.0 ones
post #11 of 23 (permalink) Old 04-01-2007, 01:44 PM
svtbird88's Avatar
The V-8 version has an extra intermediate clutch.
post #12 of 23 (permalink) Old 04-01-2007, 07:15 PM Thread Starter
i know the 3.8 has one less clutch but I could've sworn the 4.2 has the same cluthes as the v8.
post #13 of 23 (permalink) Old 04-03-2007, 09:23 PM Thread Starter
now I know the explorer transmissions are natorius for dieing. Are the 4r70w's in the 5.0s not the trans that like to die?
post #14 of 23 (permalink) Old 04-03-2007, 09:53 PM
thats the first ive heard. A transmission that "is notorious" can be chalked up to many different reasons, not maintaining clean fluid, driving style, inadequate cooling, etc....
Obvisously, if you were to set this up as a performance application, one would ensure a deep sump pan is used, run a large cooler, j-mod it, make sure it has Mercon V. Also, I would find the cheapest 5.0 4R70W I could find and of course overhaul it with new seals, gaskets, and friction materials.
post #15 of 23 (permalink) Old 04-03-2007, 09:56 PM Thread Starter
yeah it may have been the trans that was in the older explorers that I thinking about and not the 4r70w
post #16 of 23 (permalink) Old 04-04-2007, 12:05 AM
LOLA's Avatar
I believe it is the 55RE that are the problem trannys. I have a '97 Mountaineer with a 5.0/4R70W with 190,000 on it & it's never been touched.
LOLA is offline
post #17 of 23 (permalink) Old 04-04-2007, 01:57 PM
svtbird88's Avatar
The 5R55 is behind the 4.6 simular to the one in all 04 and up mustangs.
post #18 of 23 (permalink) Old 04-04-2007, 03:09 PM
05. 04 GTs got the 4R75W
post #19 of 23 (permalink) Old 04-04-2007, 07:31 PM
svtbird88's Avatar
Sorry for the typo 05 up have 5R55s.
post #20 of 23 (permalink) Old 04-04-2007, 10:06 PM
The 4.2 truck transmissions have the same clutches as a V8. At least the one I robbed the guts from did. I've read on here the 3.8 valvebody is more suitable to jmod.
icantdrive55 is offline
post #21 of 23 (permalink) Old 04-05-2007, 05:35 PM Thread Starter
i'm just going to go with a 3.8 one. I can get some with less than 30k miles on it for $300. The 3.8 will be strong enough for what I got now and if it starts to go I'll rebuild it and stil be ahead of what the 4.2 or 5.0 ones cost
post #22 of 23 (permalink) Old 04-07-2007, 11:14 PM
actually the 02 v6 mustang trannys have the same guts as the 4.6 gts so does the 03 v6 but no teeth on the output shaft of the 03s
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #23 of 23 (permalink) Old 04-08-2007, 12:09 AM Thread Starter
thanks for that info, I'll look for an 02 then
