AOD died on my 5.0l LX - Page 2 - TCCoA Forums
 33Likes
post #31 of 37 (permalink) Old 09-05-2019, 09:24 PM
Zep5.0's Avatar
Great effort on this. It's coming along nicely!
ErwinN likes this.
Zep5.0 is online now
post #32 of 37 (permalink) Old 09-05-2019, 09:49 PM
This thread is awesome! I love the outside the box approach and quality of execution
Grog6, CDsDontBurn and ErwinN like this.
post #33 of 37 (permalink) Old 09-08-2019, 04:26 PM Thread Starter
ErwinN's Avatar
Here's a photo of the slotted hole that needs to be extended. If anyone wants to know what the black box mounted to the cross member is, it's a metal box filled with sand or metal particles, used for vibration dampening. It weighs more than a kilo. So if you want easy weight savings, take a drill and drill out the two rivets that attach it to the cross member.
May the downforce be with you.
ErwinN is offline
post #34 of 37 (permalink) Old 09-08-2019, 04:40 PM Thread Starter
ErwinN's Avatar
I extended the shift lever rod by cutting it in half and welding a piece of pipe in between. I was planning on fabricating a new bracket for the shift lever but eventually ended up just using the old one and some threaded rod instead. I'm not sure where I will mount the silent block. In the front gives more clearance, but in the back is sturdier. I will try out both perhaps.
MaddMartigan and CDsDontBurn like this.
ErwinN is offline
post #35 of 37 (permalink) Old 09-08-2019, 07:47 PM
MaddMartigan's Avatar
Have you considered making a 3 sided box for the extension? You could just put some plate on the outside of the extension pieces and weld it all together. That would make it all a lot stronger and more reliable.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #36 of 37 (permalink) Old 09-09-2019, 01:56 AM Thread Starter
ErwinN's Avatar
A three sided box was my initial plan, but it's not the extension rods that flex, it's the silent block. The rods only create more leverage when put behind it.
I think I'm just going to raise the the original bracket a bit so that I have more clearance. Maybe even connect the shift lever part to the tunnel itself. We'll see.
ErwinN is offline
post #37 of 37 (permalink) Old 09-09-2019, 08:46 AM
quickford's Avatar
This is really cool. I can't say I understood all the technical details, but I can tell you did a lot of custom modifications and engineering to make this swap work, and that's really neat.
ErwinN likes this.
Current poor life choices: 1991 Mercury Cougar XR7, 1998 Lincoln Town Car, 2005 Ford Focus ST, 1997 Ford Probe GT.
Previously: 2015 Focus, 1996 Thunderbird, 1998 Taurus, 1989 Escort.
quickford is offline
Similar Threads
95 lx 4.6 died while driving merkur92 General Tech 12 05-18-2009 08:41 PM
CCRM or IRCM...what can I use for a 92 5.0L if I cant find another 5.0l? MZ-Bird General Tech 6 08-02-2008 09:21 PM
So my fuel gauge aint working and then my temp gauge died on me! Tx_Cat General Tech 1 10-31-2006 11:33 PM
5.0L vs 5.0L King_V Engine - 5.0L & 5.8L 4 10-26-2004 10:53 PM
Pics of my 93 Tbird LX 5.0L H.O FordThunderbird Videos/Images 8 10-13-2004 03:35 PM
