Trans not shifting after replacing valve body - TCCoA Forums
post #1 of 7 (permalink) Old 08-10-2019, 03:27 AM Thread Starter
Replaced the valve body on my 91 thunderbird 5.0 aod, with a performance automatic transmission street/strip valve body, now it won't shift out of first. It will go into park, neutral, but won't shift out of 1st when in drive or overdrive. Fluid level is fine, just looking for ideas of where I could've gone wrong.
Fordmuscle53 is offline
post #2 of 7 (permalink) Old 08-10-2019, 09:52 AM
Originally Posted by Fordmuscle53 View Post
Replaced the valve body on my 91 thunderbird 5.0 aod, with a performance automatic transmission street/strip valve body.
I'd say about right there.
Who built the VB?
Grog6 is online now
post #3 of 7 (permalink) Old 08-11-2019, 02:50 AM Thread Starter
Who built the VB?
Performance automatic transmissions
post #4 of 7 (permalink) Old 08-11-2019, 10:11 AM
dDUBb's Avatar
You should still have some sort of manual engagement unless you did something wrong during install or they gave you a VB with a stuck valve, or you are missing check ball, etc .. take the VB back out, and do it all over again - or contact the seller of the VB for assistance. Only way to check the VB is to bench test or throw a pressure gauge on the trans to verify fluid is going where it needs to.
dDUBb is offline
post #5 of 7 (permalink) Old 08-11-2019, 01:13 PM Thread Starter
Ok I appreciate it, I will have to call them monday
post #6 of 7 (permalink) Old Yesterday, 09:23 PM Thread Starter
Called them today, said it was most likely the TV pressure needs adjustment
post #7 of 7 (permalink) Old Yesterday, 10:18 PM
dDUBb's Avatar
The trans should still shift even if you disconnect the TV cable from the Throttle body completely .. although it would shift at full pressure resulting in premature failure eventually. Unless you goofed up somewhere during the install on the VB end of the TV cable.
Need more information ..
What did you do .. exactly .. during removal / installation ?
and more importantly ..
Why did you replace the valve body in the first place ?
dDUBb is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
charlotte94
Similar Threads
Trans Running Hot, Not Shifting Bill Rivers 4R70W Transmissions 27 01-05-2013 01:13 AM
99 trans valve body??? djoc2000 Drive Train 2 11-15-2005 05:47 PM
Not MLPS, Not TPS, Not Shift Solenoids, Not Internal...What's going on? EPelezo Drive Train 43 06-05-2005 04:40 PM
Shifting Gears...Replacing Brake Light Switch ???? BeirutsFinest General Tech 7 08-25-2003 11:07 PM
