Flywheel for swap - TCCoA Forums
 2Likes
  • 1 Post By ROLLINTHUNDER
  • 1 Post By S4gunn
post #1 of 6 (permalink) Old 06-07-2019, 06:17 PM Thread Starter
ROLLINTHUNDER's Avatar
Flywheel for swap
Didn’t know if this would be better for drivetrain section or engine. Recently did a 347 build. Had it running in car with the M5r2 trans. Used a stock 95 f150 flywheel that the engine builder SAID he rebalanced it to 28oz to match the stroker kit. I see where he did drill holes in certain areas of the flywheel but some suggest to just buy one that is already 28oz balanced. The motor did have a vibrating shake to it. Anyone know the best place to get one or have a part number for it?? Thanks guys!
Eibach pro kit springs w/rear cobra bilstiens, rear disc conversion, 2000 Cobra R wheels, 89 SC track-lock swap w/mark 8 cv shafts, 89 front and rear sway bars
ROLLINTHUNDER is offline
post #2 of 6 (permalink) Old 06-07-2019, 09:01 PM
MaddMartigan's Avatar
Originally Posted by ROLLINTHUNDER View Post
Didnt know if this would be better for drivetrain section or engine. Recently did a 347 build. Had it running in car with the M5r2 trans. Used a stock 95 f150 flywheel that the engine builder SAID he rebalanced it to 28oz to match the stroker kit. I see where he did drill holes in certain areas of the flywheel but some suggest to just buy one that is already 28oz balanced. The motor did have a vibrating shake to it. Anyone know the best place to get one or have a part number for it?? Thanks guys!
OK, first thing is first. If you are using a 347 then it's based on a 302 and if he used a crank based on a 302 from the 80's through the 90's then it's a 50oz. imbalance, not a 28oz. This is very important because that shake is probably an indication of the wrong flywheel.
Get that straightened out before you worry about getting another flywheel. If you aren't sure what crank you have then I would check that out. Drilling holes in a flywheel to get you there sounds pretty hack.
Once you do, I'm running a Fidanza lightweight flywheel that I have the part number for that will help you. The bright side is that those flywheels can be 0 balance, 28 or 50oz.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #3 of 6 (permalink) Old 06-10-2019, 07:31 PM Thread Starter
Thanks Madd. I was hoping you’d chime in. I first sent him a 50oz balancer at the beginning of the build. He called back and said the company he got the kit from said it was a 28oz and not a 50oz. The motor is 95 mustang based. He gets his kits from a company called Liberty Performance out of Louisville Ky. I may call them and see if they have a record of it. That flywheel you are using sounds like a winner. If you have the part number I’d appreciate that. Thanks bud!
MaddMartigan likes this.
post #4 of 6 (permalink) Old 06-12-2019, 04:31 PM
S4gunn's Avatar
Randy:
They make 28oz imbalanced cranks just like they make 0oz internally balanced cranks so it's not a given what he has/needs
"Almost all 347 stroker kits are 28oz imbalance"
https://www.allfordmustangs.com/foru...balancing.html
It seems to hold true of my random sampling of all 68 347 stroker kits available on summit
https://www.summitracing.com/search/...ement/5-7l-347
CNC motorsports seems to have 10 internally balanced 347 kits and 14 balanced to 28oz
https://www.cnc-motorsports.com/engi...s/internal-yes
It seems like Liberty Perf has 3 cranks for a 302 online.
347 kits can be either 3.25 or 3.4" stroke depending on the pistons (dish or dome) so it can be either one of these. All 3 are internally balanced.
http://www.libertyperformance.com/pr...d.php?tags=526
Q: So, what did your builder do?
Q: Is your crank actually internally balanced (which is arguably the best for higher RPM - it's probably what i'd go with if I ever had another project car and a 302) and you have a 50oz flywheel drilled out to 28oz?
Long video about balancing a crank + flywheel (rotating assembly). This is what my builder guy did when I gave him my harmonic balancer + 302 crank + flywheel + pistons (he weighed them to come up with the right bob weights). My guy also gave me a record of all the measurements he made and what he did. My setup was stock so very little material was required to be removed from the harmonic balancer to match the stock 50oz imbalance.
http://goo.gl/csaet4
S4gunn is offline
post #5 of 6 (permalink) Old Yesterday, 10:42 AM Thread Starter
Thanks S4. Im pretty positive he said 28oz internally balance. He did have the balancer and the flywheel he had to modify and balanced them all together. He weighed the rods and marked them i did see that. Couple things though. He bored it 40 over instead of 30. He did order 40 over pistons. Also tried to tell me you don’t have to notch the block. Wrong! I notched it myself before sending it back to him. Right now he has it because I believe it has a wrist pin issue on the far back cylinder. The guy knows what he is doing but is mainly a chevy builder.
post #6 of 6 (permalink) Old Yesterday, 10:52 AM
Thanks Madd. I was hoping youd chime in. I first sent him a 50oz balancer at the beginning of the build. He called back and said the company he got the kit from said it was a 28oz and not a 50oz. The motor is 95 mustang based. He gets his kits from a company called Liberty Performance out of Louisville Ky. I may call them and see if they have a record of it. That flywheel you are using sounds like a winner. If you have the part number Id appreciate that. Thanks bud!
Here is what I'm using: Fidanza 186511 164 Tooth Aluminum SFI Approved External Balance Flywheel
You're going big, may as well go big.
FRPP 42# injectors
3.27 gears
M5R2
OMGHI2U
Similar Threads
Flywheel for 93 5.0 with M5R2 Swap Byros M5R2 5 Speed Transmissions 8 09-29-2015 06:30 PM
t-56: cuple trans swap Q's flexplate/ clutch/ flywheel/ pilot bearing... tbirdkilla Drive Train 9 06-02-2007 04:14 PM
engine swap,changing flywheel to flexplate big mike Drive Train 9 06-28-2005 02:23 PM
what flywheel and clutch????5-speed swap shockwavef399 Engine - 5.0L & 5.8L 9 06-30-2004 05:16 AM
M5R2 swap info needed..Flywheel Mark M. TCCoA VP Drive Train 0 03-21-2004 07:41 AM
