Hey I am doing a T45 swap into a 95 4.6 cougar. I got the T45 from a 96 GT. I need to buy a flywheel and just dont know if I need a 6 bolt or 8 bolt flywheel. Anybody know?
do you have the stock engine? if so it will be a 6 bolt, if not you would have to check the crankshaft. slide under the car pull the inspection cover off of the trans and count the bolts that are holding the flexplate in.
Related Threads
TCCoA Forums
1.5M posts
26.9K members
Since 2002
