Another Mark VIII driveshaft question. - TCCoA Forums
post #1 of 8 (permalink) Old 07-29-2002, 01:04 PM Thread Starter
How do I tell that the driveshaft that I am looking at is a 93 Mark VIII vice another year? I found a wrecking yard that says he has two of them but I want to make sure I am getting the right one.
mikes97 is offline
post #2 of 8 (permalink) Old 07-29-2002, 01:05 PM
pretty sure the two-piece ones will clearly be two pieces welded together
Robinson is offline
post #3 of 8 (permalink) Old 07-29-2002, 02:22 PM
Talking Re: Another Mark VIII driveshaft question.
Here's a picture DanU posted a long time ago. It shows the
color code for the one piece shaft. If you're lucky, maybe
you'll still be able to see those three bands on the ones
in the bone yard.
Good luck,
MagerThom is offline
post #4 of 8 (permalink) Old 07-29-2002, 03:29 PM Thread Starter
thanks MagerThon,...but does the two piece d/s
have a three color bands too?? because if so i screwed because i am color blind like a dog. Also as a far as the two pieces welded together did not seem clear to me? I was under the impression that the two piece type was a tube in a tube???? So any more clearification would help me,....but thanks for the inputs so far
mikes97 is offline
post #5 of 8 (permalink) Old 07-29-2002, 05:14 PM
Re: thanks MagerThon,...but does the two piece d/s
This is what you want... The color doesn't matter as I pulled mine out of a 93 Mark and the color stripe it has are different. The two piece shaft has a small gap approx 6-8 inches up from the rear yoke. The one piece is welded at that area.
Blown94SC is offline
post #6 of 8 (permalink) Old 12-24-2009, 04:04 PM
beamerboy46350's Avatar
Send a message via Yahoo to beamerboy46350
Why cant I see these "pics"???
beamerboy46350 is offline
post #7 of 8 (permalink) Old 12-24-2009, 05:29 PM
machausta's Avatar
They are links offsite from 2002. Not all websites from 2002 exist today.
2011 Dodge Durango Crew 5.7L HEMI
2001 Volkswagen Beetle GLX 1.8T
machausta is offline
post #8 of 8 (permalink) Old 12-25-2009, 09:01 AM
look at the rear yoke area, if there is a gap in the shaft its the two piece.
if its solid from one end to the other its a one peice.
howa about posting a pic of the shaft you are looking at?
need to see the last two feet of the rear of the shaft
1995 Lincoln Mark VIII "Grandmas Car"
400,480 miles *STOLEN 04-13-08*
98 Mark VIII LSC
STONE
STOCK
SLOW
NO
MODS
HERE
XLRVIII is offline
