solid rear axel - TCCoA Forums
post #1 of 9 (permalink) Old 08-07-2007, 06:33 PM Thread Starter
firescout211's Avatar
Send a message via AIM to firescout211
solid rear axel
ok, time to start running with the big dogs. i have a potential power adder going on my car. a custom suspension racing shop told me that i could put a fuel cell in my trunk with a sumped pump. and a 99-04 gt rear axel would bolt up without too much modification. what do you guys think?
5.4 32 valve monster being built
firescout211 is offline
post #2 of 9 (permalink) Old 08-07-2007, 09:31 PM
VicRattlehead's Avatar
what shop?
CMP Drag Racing
VicRattlehead is offline
post #3 of 9 (permalink) Old 08-07-2007, 09:35 PM
The Great Obucina's Avatar
I think they are fulla**** and there are quite a few cars running very quickly with an IRS.
"Booyah". Stu Scott.
The Great Obucina is offline
post #4 of 9 (permalink) Old 08-07-2007, 09:39 PM
Agreed on less need, I know of one pulling 1.6X 60' and borderline 12.1s on a cobra rear and tbird halfshafts through an auto trans
a black car.
Sophosis is offline
post #5 of 9 (permalink) Old 08-07-2007, 09:42 PM
Regardless of whether it's needed or not, the "without too much modification" part is a crock. Mustangs can swap solid axle and IRS without much effort. The MN12 is a different animal. I'm sure it could be done, though; anything can be done with enough time and money.
It's only funny until someone gets hurt.
Then it's freaking hilarious.
Adventures in ChumpCar Racing
Tobey is offline
post #6 of 9 (permalink) Old 08-07-2007, 10:42 PM
#1 - It has been done quite a few times.
#2 - It requires an extensive amount of work.
#3 - Unless you're planning on running quicker than mid-10's, why?
-Rod
post #7 of 9 (permalink) Old 08-08-2007, 12:12 AM Thread Starter
because of reason #3 built motor + blower + snow system + sticky tires = broken shafts
post #8 of 9 (permalink) Old 08-08-2007, 06:14 AM
What the heck are you doing for an engine? There are a couple full weight MN12's now that are pulling 1.5X 60' times and running well into the 10's on completely stock IRS (save for gear/diff changes). They aren't breaking shafts.
-Rod
post #9 of 9 (permalink) Old 08-08-2007, 06:17 AM
Also, for info on the solid axle swap, run a search over on sccoa.com. You'll find quite a bit of info.
-Rod
