4.10s or 4.30s - TCCoA Forums
post #1 of 20 (permalink) Old 10-04-2007, 03:54 PM Thread Starter
MaleWhore
smokymance's Avatar
4.10s or 4.30s
i got 3.73s on the car right now and im thinking i want to go up higher...
i barely drive the car on the freeway and its not going to anytime soon...its just a fun car so i want to go to a lower gear....
what do u guys recommend 4.10s or 4.30s? i talked to some guy that had 3.73s and went to 4.10s and he didnt notice that much of a difference exept a tad quicer off the line of coarse...
any comments? experiences with these gears?
smokymance is offline
post #2 of 20 (permalink) Old 10-04-2007, 06:03 PM
ZackG's Avatar
if you do go with anything higher than 3.73, you should have the forced lube mod, a better converter and a better driveshaft. And also, how do you plan on getting traction from a dig? I havent thought about that yet. I am staying with my 4.10's, but its really up to you
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #3 of 20 (permalink) Old 10-04-2007, 06:39 PM Thread Starter
MaleWhore
smokymance's Avatar
i got a marauder TC on the car....and driveshaft still stocker...
plans are to get rid of the 4r70w and get a t56 that i almost have lined up for the car...6 gears with a 4 30 shouldnt be that bad....
then the hub swap is under plans also so that should give me a bigger variety of wheels and tires to go with that stick...
post #4 of 20 (permalink) Old 10-04-2007, 06:49 PM
ZackG's Avatar
well.. if you go with a manual, 4:30 is a little tall. I wouldnt go above 3.73's with a stick. If you really launch it hard, you run the risk of breaking half shafts with a tall gear ratio.
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #5 of 20 (permalink) Old 10-04-2007, 07:35 PM Thread Starter
MaleWhore
smokymance's Avatar
ehh...u live once...half shafts can be replaced...lol
post #6 of 20 (permalink) Old 10-04-2007, 07:35 PM
96bird's Avatar
4.30's are actually shorter than 3.73's not taller.
If you are using the LS1 T-56 then the 4.30's will work perfect and be great on the highway with the 0.50 6th gear.
Russell
96bird is offline
post #7 of 20 (permalink) Old 10-04-2007, 07:37 PM
coggonobrien's Avatar
what's the forced lube mod? i've been running 4.11 gears for 3 years now without it or any problems
coggonobrien is offline
post #8 of 20 (permalink) Old 10-04-2007, 07:44 PM
ZackG's Avatar
its just a precautionary measure since there's more wear on the tailshaft in the tranny. Its's where you drill a hole in the tailshaft housing and run a line to it so fluid gets to the end of the transmission. and yeah, you're right, i thought i had the shorter/taller thing down, but i dont.
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #9 of 20 (permalink) Old 10-04-2007, 09:23 PM
tbirdtess's Avatar
3.90's
Hello
I have 3.90's in my car. I loose about 300rpm with 4.10's
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #10 of 20 (permalink) Old 10-05-2007, 07:05 AM
Toombs's Avatar
Don't fear the gear....I don't.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- DirtyDog Converter (3,800)
- SCT Micro Tuner from Blue Oval Chips
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #11 of 20 (permalink) Old 10-08-2007, 08:16 AM Thread Starter
MaleWhore
smokymance's Avatar
i got a set that i want to buy.... part number M4209-G430-M. would this fit? its for a 8.8 ford mustang rear end...
post #12 of 20 (permalink) Old 10-08-2007, 08:36 PM
ZackG's Avatar
need to know more than just a part # really. but
http://store.summitracing.com/egnsea...115+4294901314
any of those will work. I hear FRPP is easier to install. And you'll also need an install kit
you probably want the ones that cost more than the $33 one.
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #13 of 20 (permalink) Old 10-08-2007, 08:42 PM
Toombs's Avatar
I don't know about that M suffix, but the rest of the part number matches my 4.56 set.....except for the 430, which is of course 456 in my P/N.
If it's for an 8.8, it should work fine.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #14 of 20 (permalink) Old 10-08-2007, 10:07 PM
driller's Avatar
M-4209-G410 was the P/N for the 4.10s when I bought them.
I think the -M suffix stand for the gears manufactured by Motive.
driller is offline
post #15 of 20 (permalink) Old 10-08-2007, 10:12 PM Thread Starter
MaleWhore
smokymance's Avatar
well im about to get the 4.30s and i guess its recommened to get the install kit...ill have the pumpkin taken to a shop for them to do it and throw it on the car myself...
post #16 of 20 (permalink) Old 10-09-2007, 05:33 AM
ZackG's Avatar
sounds like a good plan. most shops charge around $200 to install gears (atleast around here they do)
97 Tbird 4.6
Vortech at XY psi
Yummy.
ZackG is offline
post #17 of 20 (permalink) Old 10-09-2007, 07:04 AM Thread Starter
MaleWhore
smokymance's Avatar
the thing is that i can do all the work myself, but iv heard that if you dont know what your doing when ur taking a differential apart; your in big trouble, or will be when u get it on the road...
post #18 of 20 (permalink) Old 10-09-2007, 07:46 AM
Toombs's Avatar
...if you dont know what your doing when ur taking a differential apart; your in big trouble, or will be when u get it on the road...
Quoted for truth. This is not a simple parts changer job, and if you don't know what you're doing, it's best left to someone who does.
Mike
- DOHC 4.6
- 4.56 Trac-Loc
- 13.24 @ 103mph
ToombsRacing.com
Toombs is offline
post #19 of 20 (permalink) Old 12-01-2007, 09:42 AM
Kevin's Avatar
Send a message via AIM to Kevin
Yeah, don't do the work yourself unless you know what you're doing. You have to know what shims to use, how much to crush the one washer, and on and on.
But you could pull the pod from the car yourself, that's not too hard. Take it to a guy and tell him to swap the gears.
4.56's might be fun, but I'll stick to my 4.30's. Am pulling about 2500 rpm at about 65mph.
Because of the gears I don't really go over 65 anymore, and pretty much stay in the right lane for the little freeway driving I do. Other than that though, it's alot of fun to blow just about everybody away at a stop-light with only 1/2 throttle .
1992 Mercury Cougar XR7 5.0 - Rust In Pieces
1995 Mercury Cougar XR7, rust free Florida car - future 5.0 project
Kevin is offline
post #20 of 20 (permalink) Old 12-01-2007, 02:17 PM
954.6tbird's Avatar
AMEN BROTHER!!!
Ed
94 Thunderbird 4.6 PI
954.6tbird is offline
