Pinion Seal Replacement - TCCoA Forums
post #1 of 2 (permalink) Old 10-07-2007, 08:07 PM Thread Starter
miller1995's Avatar
Ok had my diff rebuilt a few months ago and the pinion seal is now leaking preety bad. I have a seal sitting here, is this something I can easily replace myself? I would really like to avoid having my car down while the diff is being worked on by someone else. Any one have any tips or tricks to replacing the seal?
-Bryan Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #2 of 2 (permalink) Old 10-07-2007, 08:19 PM
If you feel comfortable rebuilding your diff yourself, then yes you can. The good thing is that you will be using the same gears, so just keep track of which shims came from where and make sure they all go back in the same place, and you should get the same tooth pattern. Just make sure to use a new crush sleeve and make sure you have the right backlash and rotational drag.
