Quick Questions - TCCoA Forums
post #1 of 8 (permalink) Old 01-08-2008, 11:13 AM Thread Starter
Quick Questions
I installed a set of addco bars and now I have a tire wear issue on the rear passenger tire. I know what causes it, the rear bar doesn't allow the IRS to fully function. For example if I pull into a parking lot that has an incline in the entrance my rear passenger tire will not keep contact with the ground or to spin with slight contact with the ground causing extra wear on that tire. What would be my options in fixing this issue?
Christopher
cmcconkey is offline
post #2 of 8 (permalink) Old 01-08-2008, 07:31 PM
Chapter Director Coordinator
jamesD's Avatar
take the bars out
it shouldn't be that stiff.. what kind of end links do you have on there?
I bust ARP bolts by hand...
If Guns kill people, then...
...pencils miss spel werds
~Gun Owners of America
jamesD is offline
post #3 of 8 (permalink) Old 01-08-2008, 07:55 PM Thread Starter
I had the package put on at a performance shop here locally. I took them everything that was shipped from Addco and said "Here install it" and they called me back later that day saying that they would have to keep it over night because the front bar was being a pain.
Also the entrance that I am speaking of is a 90 degree turn off a road that is about 2 foot lower than the parking area, and the 2 feet that you have to go up is about a 4 foot distance (if that made sense).
Would the end links be included in the Addco order?
Christopher
post #4 of 8 (permalink) Old 01-08-2008, 08:17 PM
Look at the end of the bars, behind the rear wheels, and see:
How long is the thing from the bar to the lower control arm,
And is it pointing up and down, or at an angle?
Sounds like a travel limitation from the swaybar hitting something...
Grog6 is online now
post #5 of 8 (permalink) Old 01-08-2008, 08:33 PM Thread Starter
I will get under there tomorrow and take some pics and see what yall think.
Christopher
post #6 of 8 (permalink) Old 01-08-2008, 08:39 PM
jamesD's Avatar
it should be flat
addco does include new end links.. the question is whether or not you told them you had the lowering kit.. because you would need shorter links
jamesD is offline
post #7 of 8 (permalink) Old 01-08-2008, 08:41 PM Thread Starter
Well actually the money ran out on the lowering kit so I have yet to get it installed. I am still running at original ride height.
Christopher
post #8 of 8 (permalink) Old 01-10-2008, 08:26 AM Thread Starter
Well I didn't make it out yesterday to take pictures, I had to go and look at a wedding chapel. I will attempt to do it today when I get off of work.
Christopher
