Play in Differential Housing? - TCCoA Forums
post #1 of 6 (permalink) Old 01-21-2008, 12:26 AM Thread Starter
94trouble's Avatar
Send a message via AIM to 94trouble
is there supposed to be play in the differential housing? when i took my car into my school auto shop and put it on the lift, i tried to check the differential fluid. But the plug wouldnt budge, and i couldnt check the fluid. Anyways when i was trying to get the plug off i noticed that the whole differential moved as i tried to get the plug off, is this normal? im thinking it might be because of the IRS? correct me if im wrong, thanks
94trouble is offline
post #2 of 6 (permalink) Old 01-21-2008, 08:40 AM
JMags's Avatar
The differential has three rubber isolated mounts. It should be able to move a little to absorb the 'impact' from launches I believe.
Black '97 XR7
Magnaflow almost true duals w/ 3" rolled tips
Transgo bucking kit w/ aux cooler
JMags is offline
post #3 of 6 (permalink) Old 01-21-2008, 09:10 AM
sik97bird's Avatar
how much movement are we talking about???
sik97bird is offline
post #4 of 6 (permalink) Old 01-21-2008, 09:22 AM
ClintD's Avatar
unless you're using somthing like a 3 foot breaker bar, you relay shouldn't notice any play.
ClintD is offline
post #5 of 6 (permalink) Old 01-21-2008, 03:10 PM Thread Starter
94trouble's Avatar
very little, i let my teacher try to loosen the plug too, just to see if i was going crazy. Maybe about an inch or less of movement
post #6 of 6 (permalink) Old 01-21-2008, 04:26 PM
tbirdtess's Avatar
Bushings
Hello
Sounds like bad bushings. You shouldn't get play with a wrench.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
