rebuilding the diff... - TCCoA Forums
post #1 of 9 (permalink) Old 02-02-2008, 07:53 PM Thread Starter
and the god dang king pin will not come out.
I took out the bolt that holds it in, and it was snapped off(the bolt broke in 2 pieces), well I could not get the pin to rotate enough to let the other half drop out, so I drilled in the side of the king pin, and got the rest of the bolt out.
Well, the damn pin still will not rotate but maybe 20 degrees, and will not come out.
I can beat on it(not mushrooming it), and it does not come out, even though it moves freely with some play where it sits.
What am I doing wrong?
I have another diff taken apart, and the pin goes in and out freely...
I'm lost.
post #2 of 9 (permalink) Old 02-02-2008, 08:29 PM Thread Starter
I'm probably naming things wrong....but to better say what happend, the bolt that holds the crosspin in(the bolt that bolts into the carrier) broke, but I got all the broken bolt out, but the pin still will not come out..
post #3 of 9 (permalink) Old 02-02-2008, 08:39 PM
ClintD's Avatar
How the hell did that bolt break?
I'm trying to figure it out and the only thing I could think of was one of the spiders seizing onto the pin, but I can't see you're car doing a one legger down the track!
ClintD is offline
post #4 of 9 (permalink) Old 02-02-2008, 08:41 PM
95xbird's Avatar
His car is a one legger.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #5 of 9 (permalink) Old 02-02-2008, 09:12 PM
ClintD's Avatar
If it is an open carrier, The I would say it's time for a new one.
ClintD is offline
post #6 of 9 (permalink) Old 02-02-2008, 09:36 PM Thread Starter
It was a track lock unit(the whole pumpkin), that I pulled out of a junkyard car.
post #7 of 9 (permalink) Old 02-02-2008, 09:38 PM Thread Starter
I've decided to hell with it....I have another t-lok unit out of a Mustang 8.8.....I'll just remove the little c-clips on my axles, instead of maching the side gears.
Anyone see a problem with this?
post #8 of 9 (permalink) Old 02-02-2008, 09:42 PM
jk69cat's Avatar
break out the fire wrench , get that baby out!
mn12 less!
jk69cat is offline
post #9 of 9 (permalink) Old 02-02-2008, 09:44 PM Thread Starter
the thing is, the pin moves, the spider gears move, the bolt is out, and no matter how hard I hit the mother, either way, it just won't budge.
My hands freakin hurt.
I don't have a torch.......aarrgghhhhh!
