What Gears? - TCCoA Forums
post #1 of 20 (permalink) Old 02-04-2008, 09:20 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
Send a message via AIM to ZeroRain
What Gears?
Hey friends I did my 5.0 5spd swap into the 96 bird and I'm wandering what gears I should go with. Right now I have the stock 96 v6 gears in it. I plan on doing a decent amount of highway "65-70". Also on the same note I would like to take it to the strip and I want to pulls some good numbers so again what gears for that?
Zero
1996 Ford Thunderbird LX EFI Swapped 311 5spd "TT 5oh project"
1998 Ford Taurus SE 24v Duratec auto "DD"
1966 Ford Galaxy 500 352 Cruise-O-Matic "Restoration Car"
We don't just dream about fast toys, we build them!
ZeroRain is offline
post #2 of 20 (permalink) Old 02-04-2008, 09:46 PM
It's going to depend a lot on what 5 speed transmission we're talking about here.
-Rod
post #3 of 20 (permalink) Old 02-04-2008, 10:28 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
It's a M5r2 transmission from an 89 super coupe.
ZeroRain is offline
post #4 of 20 (permalink) Old 02-05-2008, 06:01 AM
Have you tried driving it with the 3.27's you currently have in it? I'd recommend sticking with 3.08's or 3.27's, and I definitely wouldn't go any lower (higher numerically) than 3.55's, as first gear would become worthless.
-Rod
post #5 of 20 (permalink) Old 02-05-2008, 06:28 AM
twin turbo 281's Avatar
if you also plann on still turboing the car i wouldnt go any lower than 3.27 i would stick with the 3.08 or even a 2.73 if you plann on turbo
2x95 cougars to the scapper
51 Mack A51T restoration
twin turbo 281 is offline
post #6 of 20 (permalink) Old 02-05-2008, 08:28 AM
Mark M. TCCoA VP's Avatar
When I rebuild my pumpkin I will also switch from 3.27s to the 3.31s gear set that I have kicking around.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #7 of 20 (permalink) Old 02-05-2008, 08:34 AM
4.10's or g0 home..
post #8 of 20 (permalink) Old 02-05-2008, 08:39 AM Thread Starter
5oh Transformer
ZeroRain's Avatar
4.10's or g0 home..
LOL nice. I did try the 3.27s but im turning close to 3 grand on the highway at 70. I want to be able to get decent milage because I wanna be able to drive her to and from work, also want alittle track action.
Zero
ZeroRain is offline
post #9 of 20 (permalink) Old 02-05-2008, 03:06 PM
if you run the 5spd with 4.10s and IF you ever run a turbo... boost will be very delayed. Turbos like load
post #10 of 20 (permalink) Old 02-05-2008, 03:36 PM
351cat's Avatar
Send a message via AIM to 351cat
I have an early model M5R2 trans and 3.08s plenty of pep down low and i turn 2k rpm at 70. I sorced my entire pumpkin from a mark viii, its aluminum too. I had the 3.27s and didnt like how short 1st gear was. IMHO 3.08s are a very good compromise between available torque and highway driveability. I cant even imagine 4.10's with a 3.75 first gear, ick. v8 5 speeds rock by the way.
Originally Posted by Mitch Hedberg
"Escalator Temporarily Stairs. Sorry For The Convenience."
Originally Posted by cougar_guy04 View Post
Red Green, is that you? Might consider looking into fabbing an intake setup that isn't so, well, ghetto.
351cat is offline
post #11 of 20 (permalink) Old 02-05-2008, 06:35 PM
yeah, but when your first gear is 2.46, 4.10's are great!
but this is irrelevant to the thread anyway..
post #12 of 20 (permalink) Old 02-07-2008, 10:01 AM
tbirdtess's Avatar
3.08's
Hello
I have a set of 3.08's out. not much use for them. $10.00 + S&H
I must check them first. They are from a 95 8.8 with a V8
I run 3.90's in mine, (8.8). I also have 4.10's & 3.73's(7.5)
4.10's were alittle too high with my engine. She ran out or floated @ 5600--5800rpm. Varied with the lap.
I need over 6000rpm.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #13 of 20 (permalink) Old 02-07-2008, 05:56 PM Thread Starter
5oh Transformer
ZeroRain's Avatar
Damn Paul I would get them from you but I only have a 7.5 in my bird right now. Know anyone getting rid of an 8.8?
Zero
ZeroRain is offline
post #14 of 20 (permalink) Old 02-07-2008, 08:12 PM
Leave the 3.27s in there, and change your tach to one from a V8 car. You aren't turning anywhere close to 3K at 70 with an M5R2 and 3.27s. In fact you are turning around 2200. The way the tach works is it counts the ignition pulses. With a V8, for every one engine revolution, the ignition pulses 8 times instead of the 6 that it used to. Since there are more pulses of the ignition, the tach thinks the engine is turning faster by 33% (8/6=1.3333333) so it reads 33% faster.
post #15 of 20 (permalink) Old 02-07-2008, 08:23 PM
With a V8, for every TWO engine revolutions, the ignition pulses 8 times instead of the 6 that it used to.
Fixed.
-Rod
post #16 of 20 (permalink) Old 02-07-2008, 08:25 PM
You're right, I wasn't thinking. My point remains the same though.
post #17 of 20 (permalink) Old 02-07-2008, 08:28 PM
351cat's Avatar
lol. the factory tach can be switched. pm me and i can tell ya how to do it.
351cat is offline
post #18 of 20 (permalink) Old 02-07-2008, 09:26 PM
Some can and some can't. I know the one I pulled out of an 89XR7 parts car didn't have the extra tab to ground out. I had to switch it with one out of a different cluster.
post #19 of 20 (permalink) Old 02-07-2008, 09:30 PM
jk69cat's Avatar
i have a n.i.b 331 with bearings for an 8.8 if anyone is interested
mn12 less!
jk69cat is offline
post #20 of 20 (permalink) Old 02-07-2008, 09:35 PM
351cat's Avatar
true, but as long as he started w/ an NA car, he should be able to switch it.
351cat is offline
