Tl + Tc = ??? - TCCoA Forums
post #1 of 15 (permalink) Old 02-08-2008, 05:29 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
Tl + Tc = ???
I am soon going to be upgrading my 3.27open w/TC to 3.73TL w/TC. Should I be concerned? Is there a chance i will tear anything up with both TL and TC? IDK if i have ever read anything about it around here. THanks
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #2 of 15 (permalink) Old 02-08-2008, 05:35 PM
smoothed and filled red pearl 94
94MN1246's Avatar
Send a message via AIM to 94MN1246
just brakes
as far as i know, the TC just applies brakes to the wheel thats spinning faster. a locker should keep it from doing anything in the rear since both wheels will be going the same speed. then again i am no expert on diffs.
-John
94MN1246 is offline
post #3 of 15 (permalink) Old 02-08-2008, 05:38 PM
954.6tbird's Avatar
trac lok is in your rearend, its a mechicnal unit
traction control is just like john posted, applies brakes to there is where spin , always turn it off when you race or do a burnout...im not sure if there is a way to disable it, cause id like to know
trac lok is what you want
Ed
94 Thunderbird 4.6 PI
954.6tbird is offline
post #4 of 15 (permalink) Old 02-08-2008, 05:57 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
Yes, I do know all of this, my question being, is there any dangers to anything by combining the two? Becuase that is what I will be doing. If I recall correctly with the SCT tuner you can turn off the TC.
C.Hill
- Henry Ford
- Thomas A. Edison
post #5 of 15 (permalink) Old 02-08-2008, 06:11 PM
954.6tbird's Avatar
C.Hill
ah ok
naw i dont see a problem...
Ed
post #6 of 15 (permalink) Old 02-08-2008, 10:54 PM
Here is a thread that concerns disabling the traction control permanently. May answer some of your questions.
http://forums.tccoa.com/showthread.php?t=13616
Jay
FordMan77 is offline
post #7 of 15 (permalink) Old 02-08-2008, 10:57 PM
i've been running a TL with TC for a month or two now, no problems at all. in fact i dont think the TC has even activated since the swap
post #8 of 15 (permalink) Old 02-08-2008, 11:02 PM
C.Hill
not on mn12's, our cars dont use the pcm to enable traction control, its all in abs.
post #9 of 15 (permalink) Old 02-09-2008, 12:39 AM
If you have trac-lok and it works properly, the traction control will never be engaged because it depends on the rear wheels spinning at radically different speeds, which will not occur with a properly functioning trac-lok differential.
post #10 of 15 (permalink) Old 02-09-2008, 12:50 AM
Traveler's Avatar
Just a question here.. I know that the TC uses the brakes to do its thing. I also know that the sensors for the TC are attached to the Diff as I've removed a diff or two. Is it possible, or practical, to just disable the TC by unplugging the rear sensors?
(I don't know, my car was never equipped with TC and I've since installed a TL)
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #11 of 15 (permalink) Old 02-09-2008, 01:34 AM Thread Starter
shaken, not stirred
stangboy7's Avatar
I also must state that I use this for Auto-xing and I just dont want to damage anything. Obviously I would turn TC off before i go out for a run, but just trying to be safe.
C.Hill
- Henry Ford
- Thomas A. Edison
post #12 of 15 (permalink) Old 02-09-2008, 03:30 AM
If you unplug the rear sensors, the ABS light will flash to indicate such and the whole system will disable itself. The only real way to disable it is to swap out the ABS computer or you can modify a wire single wire going to the computer IIRC.
post #13 of 15 (permalink) Old 03-28-2008, 10:47 PM
white 97 lx's Avatar
So here's my question, where are the tc sensors located and can a tl pumpkin be swapped into a tc car? I guess in simple terms can the sensor be hooked up after swapping diffs? I have an sc tl that I will be putting in soon but I also have tc. I don't want to have to deal with the whole abs problem chris eluded to
white 97 lx is offline
post #14 of 15 (permalink) Old 03-28-2008, 10:50 PM
the sensors are bolted to the case by the halfshafts, yes they can be swapped, the cases are the same, and swapping to tl has no ill effects on abs operation.
post #15 of 15 (permalink) Old 03-29-2008, 06:41 PM
thanks XR7
