trac loc or not - TCCoA Forums
post #1 of 20 (permalink) Old 03-08-2008, 01:38 PM Thread Starter
trac loc or not
Hey folks,question from a new member.I,ve got a 91 sport,I've picked up some 355 gears on ebay,I think 373 might be too steep since I do alot of highway driving and gas is getting crazy expensive up in the great white north.I'm just wondering if I've got trac loc or not.I sent away for my build sheet and it says"3.08 Limited Slip Rear Axle ratio",from what I understand a limited slip is the same as trac loc.On my door tag under AX there is a Y code which from what I've read means conventional.Any input would be apreciated.
black V8 is offline
post #2 of 20 (permalink) Old 03-08-2008, 02:22 PM
Look at the tag on your diff cover. (EXAMPLE----3L08 75A 4K11) 3L27 means 3.08:1 ratio. The L means Traction Lock. 75A is the ring gear size= 7.5 inch ring gear. 4K11 is the date code. Hope this helps! I'm pretty sure you have the 8.8 though.
1badTBird is offline
post #3 of 20 (permalink) Old 03-08-2008, 05:18 PM Thread Starter
Thanks for the info,I'm getting the oil changed tomorrow so I'll check then,just have to scrape off the undercoating.Enough snow for ya,give it a rest already eh?
black V8 is offline
post #4 of 20 (permalink) Old 03-08-2008, 05:31 PM
Some were in the treads there is a chart with the axle codes , Found out mine was a "E" under axle and its a 3:27 Trak Loc
post #5 of 20 (permalink) Old 03-08-2008, 05:37 PM
Your build sheet is saying you have a trac loc but the door tag says you have an open diff, just do a brake burn and see what happens
MikeRWK is offline
post #6 of 20 (permalink) Old 03-11-2008, 08:16 PM Thread Starter
Well had it in for an oil change today and the mechanic wouldn't look for the diff. tag because of all the undercoating,wouldn't let me down in the pit to check myself,insurance reasons.I'll just have to wait until the snow disapears and crawl underneath.When I get hung up in the snow it usually spins the passenger side but I think it occasionally gets the driver side going too,thats just what my ears are telling me,any ideas?
black V8 is offline
post #7 of 20 (permalink) Old 03-11-2008, 08:41 PM
If its only spinning 1 tie at anytime its open (especially in snow). By the way, yeah its snowing again right now. So SICK of it. C'mon summer eh?
post #8 of 20 (permalink) Old 03-11-2008, 10:21 PM
tbirdtess's Avatar
pain
Hello
I feel your pain. We received about 20" over the weekend also. I live north of Buffalo.
If you open your pumpkin & see a S in the center then it's A locker.
7.5 or 8.8 is on the outer top on the front of the housing. You need the 8.8 for the 3.55 gears. The 3.55 only came for the 8.8 - 3.45's for 7.5
I have:
3.08-8.8 out
3.27-7.5 out & under 96(2 sets)
3.45-7.5 in a 85 T-bird
3.55-8.8 out (from Bronco)
3.73-7.5 in (race car) spare
3.90-8.8 in (race car)
4.10-7.5 in (race car) spare
I have 2 -- 7.5 t-lok's 1 in 85 T-bird other is out, came with the 4.10's
Note 3.27's & 3.73's come both in 7.5 & 8.8 ring gears.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #9 of 20 (permalink) Old 03-12-2008, 07:50 AM
hey tess, how much you want for that 7.5 3:73 r&p?
post #10 of 20 (permalink) Old 03-12-2008, 07:55 AM
there DEFINATELY needs to be a sticky on this....(attn MOD)
i searched earlier last week and found the post, but here is one of them. look on the door jam....you can find out what axle code you have....you dont have to crawl under unless you know the pumpkin is not OE
http://forums.tccoa.com/showthread.p...ight=axle+code
http://www.tccoa.com/articles/gears/index.html#
1994 Thunderbird - Renegade Racing Long block, TFHS Trans, NA/SVO intake. Cam94 lives!
2010 Shelby GT500 - Black/Silver
1995 Thunderbird LX - 2000 GT PI Swap by W&S Motorsports - Sold on Tccoa.
Bill H is offline
post #11 of 20 (permalink) Old 03-12-2008, 08:56 AM
tbirdmedic's Avatar
Hey from the great white north as well.......BOWMANVILLE here
I am not sure how many non super coupes came with TRAC-LOC, so I cant be of help there, but if your only spinning one wheel in the snow, it sounds like its open, IMHO.
Anyway, if it isnt TRAC_LOC, get yourself the pumpkin from a SUPER-COUPE and do a rebuild then install those gears. You can get the kit thru the Super Coupe Club of Ontario thru our President at Fines Ford. Cost is $79+$5 for the friction modifier. I did this swap with my LX, and it was a nice upgrade. Like you, I went with 3:55. The 3:73 seemed a bit steep, but if your gonna race it at all, the taller gears will help. If you wish, come and join us for one of our weekly meets. They are posted on the SCCOA ONTARIO site. Maybe they will get off my back about being the only V8 there.
Hers the links:
http://www.sccoa.com/forums/showthread.php?t=16777 -deals thru Fines Ford
http://www.sccoa.com/forums/forumdisplay.php?f=51 -SCCOA ONTARIO CHAPTER
TbirdMedic
1995 SUPERCOUPE 5-SPEED
'95 LX with a few mods
tbirdmedic is offline
post #12 of 20 (permalink) Old 03-12-2008, 09:25 AM
btw, www.steeda.com has the track lock rebuild kit for $50 bucks.
here is a direct link.. http://www.steeda.com/products/tract...ebuild_kit.php
I have found another website that has it for $44 dollars, but I do not remember where..
actually, I just found it.. http://www.blueovalindustries.com/pr...p?pid=99012911
you should be able to go into any Ford stealership, show them the add, or have them look it up, and they should match the price
post #13 of 20 (permalink) Old 03-12-2008, 04:14 PM Thread Starter
Hey thanks for all the help guys,I'm now pretty sure this diff is open.I think I know where I can round up a trac loc pretty cheap,I'll get it rebuilt and stuff it in there with the new gears.Hey tbirdmedic what service do you work for?I got my paramedic papers in NB last year and am going through the equivalency process,doing the transfer jockey thing right now,anywho great lookin' bird.Might try to make it to one of your meets sometime.Thanks again to all.
black V8 is offline
post #14 of 20 (permalink) Old 03-12-2008, 07:55 PM
tbirdmedic's Avatar
I work for Durham out of Bowmanville. One the last years of my career. Good luck in getting your papers. We have a few East Coasters who work for us. Be nice to see you at a meet. I will PM you my phone number in case you need anything.
TbirdMedic
post #15 of 20 (permalink) Old 05-20-2008, 07:56 PM
Stroked and Blown
BlakTbird96's Avatar
Okay, i Looked at the tag in the door jam, and this is what it says:
Under AX, it says 5; under TR, it says L; under SPR, it says ccmm; under R, it says 6
What would my gear ratio be then?
My other home:
Mid-AtlanticMN12's
'96 Ford Tbird 3.8 SC
BlakTbird96 is offline
post #16 of 20 (permalink) Old 05-20-2008, 08:21 PM
From what info you gave, you have an open 3.27 differential, non-sport springs, and premium sound.
post #17 of 20 (permalink) Old 05-20-2008, 08:28 PM
Stroked and Blown
So if I go to 3.55s, how much would my gas mileage decrease? I may be buying some from a friend of mine, along with an 8.8 rear, but with the soaring gas prices with no end in sight, I'm wandering if it would be worth it. I do drive it on long trips often, but at the same time, I want to enhance all my other mods and get off the line quicker.
Cant I just have my cake and eat it to? wah, wah, wah, wah. j/k
Also, if I am driving 65-70, rpms are around 2,000-2,200, where would they be at the same speed with 3.55's?
My other home:
Mid-AtlanticMN12's
post #18 of 20 (permalink) Old 05-20-2008, 09:21 PM
i'm getting better mileage with 3.55's than i did with my 3.08's, at least around town
post #19 of 20 (permalink) Old 05-21-2008, 12:39 AM
You may notice a very small (read 0.5 - 1) MPG decrease. From an acceleration and driveability standpoint, you won't notice the difference jumping from 3.27's to 3.55's as much as you would if you went to 3.73's or from 3.08's to 3.55's. Your RPMs will be slightly higher at every speed, probably 100 or so RPM.
Shorter gears (higher numerical number) will help your mileage around town since it is easier for the car to accelerate, but on the highway is where you will notice decreases.
post #20 of 20 (permalink) Old 05-21-2008, 05:48 PM
Stroked and Blown
okay thanks. I'm probably going to get them then. Will this also get me off the line better and quicker e/t's?
My other home:
Mid-AtlanticMN12's
