highway speeds with 3.73? - TCCoA Forums
post #1 of 35 (permalink) Old 06-16-2008, 11:44 AM Thread Starter
Granted, I have zero experience messing with rear diffs/gearing.
I spoke to someone about swapping in higher gears, 3.73 or higher, and he said to watch out, I'll have more punch off the line, but I'll lose pull on highway speeds, let's say going from 60-90 would be slower. That didn't sound right to me, since I thought the only real difference is the powerband (rpm in reference to mph) is shifted and gas mileage b/c of this.
Any info would be helpful as to whether or not this is true.
97Cat is offline
post #2 of 35 (permalink) Old 06-16-2008, 01:24 PM
TCCoA Founder
Sir William's Avatar
He's an idiot. Lower gears will improve pull in EVERY gear and at EVERY speed.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #3 of 35 (permalink) Old 06-16-2008, 01:28 PM
That's BS. Your car will pull more strongly at all speeds.
He may have been referring to the loss of top speed. Your top speed will be reduced to about 85 MPH and you'll need to reprogram the computer to get your top speed back. A driveshaft upgrade is also a highly recommended with taller gears.
post #4 of 35 (permalink) Old 06-16-2008, 01:28 PM Thread Starter
sounds good. yeah, he was just some guy that I didn't even know and met at a car meet. didn't think it sounded right, but didn't have any personal experience to go with it.
97Cat is offline
post #5 of 35 (permalink) Old 06-16-2008, 01:29 PM Thread Starter
He may have been referring to the loss of top speed. Your top speed will be reduced to about 85 MPH and you'll need to reprogram the computer to get your top speed back. A driveshaft upgrade is also a highly recommened with taller gears.
will I be able to reprogram the top speed back with an xcal2? Will I be able to get the same top speed back?
97Cat is offline
post #6 of 35 (permalink) Old 06-16-2008, 01:32 PM
Yes, that's what the xcal2 is all about. You'll actually be able to go faster than the original top speed of about 106 MPH because the xcal can eliminate the top speed governor. But you must upgrade the driveshaft.
post #7 of 35 (permalink) Old 06-16-2008, 02:07 PM
TCCoA Founder
....not sure the 3.8L can push the car much over 100 regardless of what the XCal2 does for ya though.
Sir William
TCCoA Founder
post #8 of 35 (permalink) Old 06-16-2008, 02:22 PM Thread Starter
LOL... we'll see... we'll see
97Cat is offline
post #9 of 35 (permalink) Old 06-16-2008, 03:06 PM
well... i got my poor ol car up to 103mph. but that was in od, and it was about... 3500rpm - 4000rpm. i probably could of got it to 105-106, but that would of been redlining in od. I dont think i can give it more top speed than that.
How does reprogramming increase your top speed by the way, if my car red lines at 5000rpm, and the gear ratios are the same... i'm confused on how it does that.
alasich is offline
post #10 of 35 (permalink) Old 06-16-2008, 03:14 PM
shaken, not stirred
stangboy7's Avatar
I just switched from 3.27s to 3.73s last month. I just broke it in by doing the whole Hot Rod Power Tour (2400 miles) and let me tell you that the highway speeds is where I feel the most improvement. Its like the car wants to keep pulling.
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #11 of 35 (permalink) Old 06-16-2008, 03:29 PM
Originally Posted by alasich View Post
well... i got my poor ol car up to 103mph. but that was in OD, and it was about... 3500rpm - 4000rpm. i probably could of got it to 105-106, but that would of been redlining in OD. I don't think i can give it more top speed than that.
How does reprogramming increase your top speed by the way, if my car red lines at 5000rpm, and the gear ratios are the same... I'm confused on how it does that.
There's a top end (speed) limiter built into the EEC program that keeps you from over reving the driveshaft by limiting how fast you can go. The Xcal2 either eliminates or resets the limiter to a higher point and allows your car to go faster. Like you said, the V6 can only go so high but on the V8's it makes a much bigger difference.
Here are some of my video's for comparison these videos are of my car with 3.73 gears installed. The first video is where I hit the rev limiter at 83 to 85 MPH.
This video is with a program that gave me my top end back.
post #12 of 35 (permalink) Old 06-16-2008, 03:32 PM
sweet, so it pretty much wont do anything for a v6.
alasich is offline
post #13 of 35 (permalink) Old 06-16-2008, 03:35 PM
Without a program you'll be limited to 85 MPH. A program will get you back to 100 or so and 3.73 gears will get you there a lot faster.
post #14 of 35 (permalink) Old 06-16-2008, 03:38 PM Thread Starter
hmmm, so what kind of top speed will I be able to get in the end, or is 100ish it?
97Cat is offline
post #15 of 35 (permalink) Old 06-16-2008, 03:48 PM
Yea, unless you do some other mod to the car. You'll have the same top end you had before. The reason the rev limiter is there is to keep you from spinning your driveshaft off of the car. So, in order to go faster you need to get a program and you need to upgrade your driveshaft. And you need tires rated for higher speed. Going fast is a complicated process. Neglect one part of the system and it will bite you.
post #16 of 35 (permalink) Old 06-16-2008, 03:54 PM
Have you read through the Gears section of the technical articles yet?
If not, Here's a link to them.
http://www.tccoa.com/articles/gears/index.html
post #17 of 35 (permalink) Old 06-16-2008, 04:28 PM Thread Starter
thanks for the link, just read through everything. Still doesn't give me much hope on a higher top speed though... the only thing I can think is a larger overall tire/wheel diameter, but not sure how effective that would be plus I'm not a huge fan of super large wheels/tires.
97Cat is offline
post #18 of 35 (permalink) Old 06-16-2008, 06:16 PM
Just for the record, I had a 91 3.8 tbird with the speed sensor wire going to the computer cut, and was able to hit 127mph in it. That was with stock 3.08 gears, and I don't remember what the rpms were, but for people saying the 3.8 won't go over 100, you are very wrong. With 3.73s on a 3.8, and a tune, you would probably be able to go slightly faster than that since you would be at a higher rpm and making slightly more power than with the stock gears. You would definitely be able to hit 120+ though, even with a 3.8.
post #19 of 35 (permalink) Old 06-16-2008, 08:00 PM Thread Starter
yeah, i just confirmed over at SSM that the 3.8 will definitely go higher than the claimed 106, closer to 120 stock
97Cat is offline
post #20 of 35 (permalink) Old 06-16-2008, 09:24 PM
really, this is very interesting. I didnt think that the 3.8 could reach 120. i was out of rpms, although that could have something to do with my torque converter. Like i said, only had mine up to 165kmh. (digital tops out at 99)
alasich is offline
post #21 of 35 (permalink) Old 06-16-2008, 09:47 PM
theres a mod for that lol
stickysilvertbird is offline
post #22 of 35 (permalink) Old 06-17-2008, 03:21 AM
There is? I thought only the 93 clusters went higher than 99.
post #23 of 35 (permalink) Old 06-17-2008, 08:12 AM
yes there is, but i figured why bother, my car can barely see 99mph, and i never get going that fast anyway
alasich is offline
post #24 of 35 (permalink) Old 06-17-2008, 02:01 PM
What is the mod? I would definitely be interested in knowing how to make the older clusters read up to 199.
post #25 of 35 (permalink) Old 06-18-2008, 09:46 AM
http://www.coolcats.net/tech/advanced/199speedo.html
doesnt work with our cougars though
alasich is offline
post #26 of 35 (permalink) Old 08-30-2008, 02:17 AM
kick this thread up again... I can't see a MN12 with a N/A 3.8 going that fast... But yeah if you do 3.73's upgrade the driveshaft. I have done well over 140 in my tbird. I think I've got 145 left in my GPS. I don't know how Accurate my Tach is but the fastest I've ever had my bird (before GPS) was pegged out on the 145 speedo and the RPM's on the tach were 5300. But that took a very long time to get there. I'm pretty sure I was approaching a top speed.
FunktasticLucky is offline
post #27 of 35 (permalink) Old 08-30-2008, 02:54 AM
Full Metal
RedThunder94's Avatar
i beg to differ, 94 lx 3.8, it was in overdrive, od button was on the fritz.
2004 Mercury Grand Marquis GS
1999 VW New Beetle SOLD!
click here to check 'em out.
RedThunder94 is offline
post #28 of 35 (permalink) Old 08-30-2008, 01:52 PM
OMG!!!!! when mines at 165km/h the car is about 4000rpm. could i really get that much faster with the remaining rpm... dont forget i dont have a locking torque converter. but have 2.73 rear gears
alasich is offline
post #29 of 35 (permalink) Old 08-30-2008, 02:10 PM
Full Metal
lol, i think it had the 3.27's as soon as it would hit the limiter the tach would do a little dance between 3,000 and 4,000 when i snapped the pic it was on the low side. (this of course was done on a private road. do not attempt this at home. )
post #30 of 35 (permalink) Old 08-30-2008, 04:01 PM
if you wanna calculate out your speed I like to use Denny's Potential Speed calculator. But I think for it to work you need a locking conerter so you can get a guestimate of your RPM range. Without a locking converter and 2.73's I don't know if you'll have the power to make it that high. 3.73's are a good compromise for Hwy and speed. As of right now without a decent tune that locks the TC up when it should and no EGR the car gets anywhere from 24-26MPG on the interstate. Which really isn't bad at all in my opinion. We'll see how she does after I get all the vacuum lines hooked back up and EGR turned back on and all the work done to the car.
I'm also going to try and find a private road back around my home town. I use one that all the race guys use to test their cars on in Washington. Doubt I'll find one in NC though.
Here's the speed calculator http://www.dennysdriveshaft.com/pote...alculator.html
