75W90 vs 75W140 - TCCoA Forums
post #1 of 5 (permalink) Old 08-15-2008, 04:53 PM Thread Starter
JNT
JNT's Avatar
75W90 vs 75W140
Trying to decide which weight gear oil to use. I see both 75W90 and 75W140 recommended. Any suggestions on one over the other?
1997 Thunderbird 4.6L LX (out of commission for now)
SCT XCAL 2 From Lonnie, 02 Mustang MAF and air box, Dynomax Cat Back Exhaust, Steeda U/D Pulleys, 70MM FRPP TB, Dual Piston Calipers, KVR Rotors, Alpine CD, Polk Speakers
1996 Thunderbird 4.6L LX Stock
1994 Thunderbird SC (Needs Work, for sale)
1996 Bronco XL - 2003 Escort ZX2 wrecked - 1996 Bronco XLT Sport
Project Car: 69 Lincoln Continental
JNT is offline
post #2 of 5 (permalink) Old 09-16-2008, 10:56 PM
sik97bird's Avatar
75w90 is what you should use, 75w140 is to heavy of an oil. 1400hp pro stock cars run 75w90 i think you'll be ok. unless your driving a semi truck or dragracing an 8,000hp top fuel dragster they use 75w140 some 80w140. think of it this way: with 75w140 your trying to stuff pudding down a pin hole.....75w90 is way more thinner
I'M BACK
97 Supercharged Ford Thunderbird with warpdrive
Check out my Gallery
vist the Man RobertP at www.robstireandauto.com
sik97bird is offline
post #3 of 5 (permalink) Old 03-19-2009, 01:49 AM
GilroyRacing's Avatar
How many quarts of gear oil does the IRS take?
GilroyRacing is offline
post #4 of 5 (permalink) Old 03-19-2009, 06:43 AM
R8D-XXX's Avatar
If empty, it will take a little over 2 bottles. If you have a trac-loc rear, don't forget to add the trac-loc addivitive. Ford dealers carry little bottles of it and you only need one. IMO, don't use the bottles at the parts stores with the addivitve already in them.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #5 of 5 (permalink) Old 08-21-2009, 05:53 PM
gear oil
All the truck diff manufacturers spec 75w90. Ford put 75w140 in mine. when I change mine I will go 75w90 synth with the friction modifier. If it can handle 2050 ft/lbs from an ISX cummins, I think it can handle my 4.6 torque.
tod340 is offline
