Speedo gear? - TCCoA Forums
post #1 of 6 (permalink) Old 10-02-2008, 03:20 PM Thread Starter
bigbirddrifter's Avatar
Question Speedo gear?
hey everyone, i just finished installing my new rebuilt pumpkin with 3.73s and was wondering if i needed a speedo gear change since i went from 3.27 to 3.73gears.. is it necessary to change the speedo gear or is 3.73s a small enough jump to where the computer will compensate?And if so what speedo gear do i need? oh and by the way, any other info for break in period since everything is new would be greatly appreciated...
1995 lx v8.
Mods: 3.73 TL,NX Express kit,ported manifolds,O/R Xpipe, 2 1/4" true duals through glasspacks. air silencer delete,3 inch cold air intake(R.M replica tube), J-MOD,b&m cooler,updated accumulators and springs removed,walbro 255 lph inline mounted pump,kirban fuel FPR ,180* drilled t-stat,hypertech module,ported upper plenum elbow,halfshafted TB/ported.
BEST N/A RUN: 15.2 @ 93mph (w/3.27TL setup)
Last edited by bigbirddrifter; 10-02-2008 at 03:22 PM. Reason: forgot to add other question
bigbirddrifter is offline
post #2 of 6 (permalink) Old 10-02-2008, 03:29 PM
just take it easy on the gears for about 500 miles or so....
post #3 of 6 (permalink) Old 10-02-2008, 03:35 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
you need the purple speedo gear. it needs to be swapped out or the speedo will be off.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 6 (permalink) Old 10-02-2008, 07:59 PM
my tb truck's Avatar
Try {transmissioncenter.net} scoll down to speedometer world and they have a lot of good info on gears and calibration.
my tb truck is offline
post #5 of 6 (permalink) Old 10-02-2008, 09:38 PM Thread Starter
thanks for the quick replies...does anyone know how much gear lube i have to put it in? I think i"ve read somewhere that 2bottles should be good or atleast till it overflows out of the overfil hole? is that correct? and how much friction modifier is needed if i use lucas full synthetic for lsd applications?
1995 lx v8.
post #6 of 6 (permalink) Old 10-02-2008, 10:05 PM
miller1995's Avatar
Go to the ford dealer and pick up two bottle of their lube and a bottle of Ford friction modifier. While you are there pick up a purple speedo gear (21 tooth); they only run about $5 last I checked.
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
