pinion seaal replacement - TCCoA Forums
post #1 of 2 (permalink) Old 11-30-2008, 05:12 PM Thread Starter
mechman1984's Avatar
My pinion seal on the differential is leaking and I was wondering what torque wrench everyone uses for this repair. The repair manual references a spec of about 15 in-lbs of torque required to turn the differential with the wheels and calipers removed. So far I have not found an inch-pound wrench that goes this low. Also what torque spec did anyone use for the pinion nut. The mustang book I have references about 140 ft-lbs but the tbird book implies you tighten the nut until you reach the orginal inch-pound reading for rotating the differential. Overall i found this method to retorque the diff flange nut very confusing and i do not understand why ford made it this way. If you have any advice on this let me know. Thanks.
Will
Will
08 Ford Ranger
95 Thunderbird V8-Sold!
mechman1984 is offline
post #2 of 2 (permalink) Old 12-01-2008, 10:39 AM
Just do it by feel......until you reach the 15 inch pounds.
