Open diff to Trac Loc - TCCoA Forums
post #1 of 34 (permalink) Old 12-07-2008, 03:43 PM Thread Starter
Scott Suzanne's Avatar
Send a message via Yahoo to Scott Suzanne
How hard would it be and what parts are needed to make an open diff into a trac loc? Could I just get a rebuilt Trac Loc unit and swap it in or is there a lot more to it than that?
Thanks.
Scott
97 Mercury Cougar "Project Eliminator" 385 RWHP 400 RWTQ
2000 GT PI 4.6 Liter with Coil-on Plug Mod, Tork Tech Inc. M112 Supercharger
BC-Automotive 4R70W and Torque Converter by Darrin, 3.73:1 rear gear, Aluminum Driveshaft,
Kooks 3/4 Length Headers, Custom Mandrel-Bent Exhaust, Vogtland 3/4" Lowering Springs,
18x9.5 GT500 Wheels, 255-45-18 front 285-40-18 rear by Custom Wheel Shop.
Under Construction
2010 Mustang GT
Daily Driver / Stock
Scott Suzanne is offline
post #2 of 34 (permalink) Old 12-07-2008, 08:11 PM
Cheapest way is to get a mustang traction lock and machine the gears. Otherwise you need an SC traction lock. I do suggest new bearings while you have it apart. I generally charge $250 in labor to build one if that gives you an idea of what it takes. You will need some special tools to do it right.
post #3 of 34 (permalink) Old 01-03-2009, 02:11 AM
94mncougar's Avatar
Send a message via AIM to 94mncougar
I have been searching and have not gotten a convincing answer on this: is it okay to just leave the circlip off of the axle, and not have the gears machined? I would think there would be no problem unless more is wrong. I read that driller said it was okay, but has there been any problems to anyone's knowledge?
Stephen
Winter mods included:
- Developing Rocker Rust
- Saggy Suspension - fixed!
- Chipped paint
- I'm sure more to come... TOTALED
94mncougar is offline
post #4 of 34 (permalink) Old 01-06-2009, 09:25 PM
decipha's Avatar
best bet is to go to a pull-a-part and just getting the whole rear diff from a sc
O&E Speed Shop - 2333 Aberdeen St. Kenner, LA
EFI Calibrator - decipha @ EFIDynoTuning
http://www.efidynotuning.com/tune.htm
decipha is offline
post #5 of 34 (permalink) Old 01-07-2009, 05:55 PM
tbirdmedic's Avatar
I swapped out my open diff in my '95 to a unit from a S/C. Had the clutch pack redone, all new fluids, and a nice set of used 3:55 gears. Probably OK if you use 3:27, but the Trac-Lok is a significant upgrade.
TbirdMedic
1995 SUPERCOUPE 5-SPEED
'95 LX with a few mods
tbirdmedic is offline
post #6 of 34 (permalink) Old 02-09-2009, 09:44 AM
PCD
Confirmed V6 Nut
I just swapped my 7.5 with 3.27s and a TracLok to a 8.8 with 3.55s and a TrakLok. What a BIG difference. I only lost a touch of MPG, too.
But the main point is getting your hands on a SC Diff and getting it put together right.
Tydlwayz may have a few SC diffs available.
PCD is offline
post #7 of 34 (permalink) Old 02-09-2009, 09:55 AM
Stephen
thats how I run mine.....mustang diff, no clips.
post #8 of 34 (permalink) Old 02-09-2009, 10:05 AM
Faster than Porkchop
cjchevez's Avatar
99 Cobra diff is a better option .
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #9 of 34 (permalink) Old 02-09-2009, 12:52 PM
Easily said,not easily done.
post #10 of 34 (permalink) Old 02-09-2009, 01:15 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
There are many Thunderbird V8's out there with Trac-Lok as well; you don't have to limit yourself to finding a Supercoupe.
tinman_72 is offline
post #11 of 34 (permalink) Old 02-09-2009, 01:24 PM
PCD
Confirmed V6 Nut
Tinman, Did the V8s come with 8.8's or 7.5's? I forgot the language on the window sticker of my V6 bird, but I thought it had a 8.8. Was wrong. Just a 7.5 with a TracLok.
PCD is offline
post #12 of 34 (permalink) Old 02-09-2009, 01:48 PM
tinman_72's Avatar
V8's came with 8.8's. IIRC, there are some n/a V6's out there that have 8.8's from the factory but they are not common.
post #13 of 34 (permalink) Old 02-09-2009, 02:30 PM
cjchevez's Avatar
Is it that they are hard to find?
I got the best deal on ebay .
Got pretty much the whole IRS from a 99 cobra except for brakes ,springs and shocks for 350.00 sold everything but the frame and differential .
The Differential fits right in with my old half shafts , maybe I got lucky .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
cjchevez is offline
post #14 of 34 (permalink) Old 02-09-2009, 02:35 PM
r429460's Avatar
I'll second that. And cougars.
r429460 is offline
post #15 of 34 (permalink) Old 02-09-2009, 06:47 PM
The issue is that they are one year only. Very hard to get your hands on. Any 28 spline traction lock carrier will work in the case as long as the side gears are machined for IRS axles. They are easily found.
post #16 of 34 (permalink) Old 02-09-2009, 08:13 PM
driller's Avatar
Stephen
I've known several that have done this and have never heard of any issues whatsoever from doing this.
driller is offline
post #17 of 34 (permalink) Old 02-17-2009, 09:10 AM
rbrown's Avatar
I see 3.8 non-SC in the yards here all the time. In fact the diff in my 95 SC right now is from a 3.8 3.27TL car. All I've seen have disc rears so that is a quick way to tell.
rbrown is offline
post #18 of 34 (permalink) Old 02-17-2009, 09:41 AM
PCD
Confirmed V6 Nut
Yes, but are they 8.8" rears in the 3.8s or like mine was, a 7.5" with 3.27s and a Trakloc?
My 7.5 didn't stand up to my N/A 3.8 with underdrives and a mildly JModded 4R70W. When I splitport the engine, I hate to think in how many pieces the 7.5 would be in.
PCD is offline
post #19 of 34 (permalink) Old 02-17-2009, 09:58 AM
rbrown's Avatar
Yes 8.8 TL. I think the key is the disc brake rears.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #20 of 34 (permalink) Old 02-17-2009, 05:05 PM
davis97xr7's Avatar
my '97 3.8 w/ rear disc brakes has a 7.5"
-Joe-
1994 Ford Thunderbird SC 5-Speed
1996 Ford Mustang SVT Cobra #1251
davis97xr7 is offline
post #21 of 34 (permalink) Old 02-17-2009, 05:19 PM
PCD
Confirmed V6 Nut
My 97 had disk brake rears and a 7.5 TL from the factory.
PCD is offline
post #22 of 34 (permalink) Old 02-17-2009, 06:24 PM
rbrown's Avatar
Ok ok I get it.
So obviously all the 8.8, 3.8's came to Texas.
Everything's bigger...
rbrown is offline
post #23 of 34 (permalink) Old 02-17-2009, 07:33 PM
PCD
Confirmed V6 Nut
Ok ok I get it.
Except women's breasts. Even Anna Nicole had to have implants.
PCD is offline
post #24 of 34 (permalink) Old 02-17-2009, 07:58 PM
rbrown's Avatar
But they were bigger implants.
rbrown is offline
post #25 of 34 (permalink) Old 02-17-2009, 09:47 PM
PCD
Confirmed V6 Nut
Stop drooling, they were fakes. Wait until you get the real ones in your hands.
PCD is offline
post #26 of 34 (permalink) Old 02-17-2009, 11:20 PM
ClintD's Avatar
just about every cougar or T-bird I have seen that had disk brakes in the rear came with a 8.8 diff whether it was a V6 or V8. in the yard I work in there are 3 cars with a E code (3.27 TL). One is a V8 with drum brakes the other 2 are V6's with disk brakes. all 3 have a 8.8 .
ClintD is offline
post #27 of 34 (permalink) Old 02-17-2009, 11:49 PM
PCD
Confirmed V6 Nut
Clint, were they 97s? I think that might be the key here. On the 97 Ford was cheaping out every way they could. All my springs have failed, and one of the replacements too. I can't wait for other things to go south, so am upgrading as fast as I can.
PCD is offline
post #28 of 34 (permalink) Old 02-18-2009, 07:02 AM
ClintD's Avatar
we only have one 97 and the rear was gone before I could check it.
I have a 89 and have had to replace all 4 springs due to failure.
ClintD is offline
post #29 of 34 (permalink) Old 02-18-2009, 07:32 AM
The big thing to remember is that if you put together the rear end without machining the gears, it is almost impossible to get the axles out.
Some people have said that leaving the circlip off makes this moot, but I wonder about the inner CV joint moving around... I know the axle can't come out, but this seems dangerous, somehow.
Wasn't it kdanner that posted about the 'difficulty' of removing the axles, with a bent toward violence?
Yeah, here it is...
http://forums.tccoa.com/showthread.php?t=108693
This is pretty good info...
YMMV.
post #30 of 34 (permalink) Old 02-18-2009, 07:38 AM
I don't daily drive mine, but the driving that it gets, I've never had a problem with my axles coming out.....
