Rear Dif...what would I need to make this work? - TCCoA Forums
post #1 of 9 (permalink) Old 12-11-2008, 04:55 PM Thread Starter
SoulCalibur's Avatar
Send a message via Yahoo to SoulCalibur
http://cgi.ebay.com/ebaymotors/06-FO...2em118Q2el1247
SoulCalibur is offline
post #2 of 9 (permalink) Old 12-11-2008, 05:25 PM
make the entire thing work?
Well, not sure of width, might be okay
need to have a upper and lower arm mounts
a watts linkage mount
probably need upper shock mounts
probably need upper coil spring pockets
then at this point what about the gas tank, that relies on the driveshaft that doesn't articulate up or down? not sure there is room
probably have exhaust issues
Find an 88 TBird for a solid rear axle. Not just the axle, the entire car
Bangster is offline
post #3 of 9 (permalink) Old 12-11-2008, 09:04 PM
SuperNewbie
supergordo's Avatar
Make it work in an MN12??
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #4 of 9 (permalink) Old 12-11-2008, 10:04 PM
5.0 bird's Avatar
Send a message via MSN to 5.0 bird
A 83-88 Thunderbird...
And then it's a moot point because it'll already have one.
Matt
1986 Cougar 5.0
1989 Mk VII LSC 5 speed (sold)
1992 Thunderbird Sport 5.0 (sold)
5.0 bird is offline
post #5 of 9 (permalink) Old 12-12-2008, 12:58 AM
alicks's Avatar
Originally Posted by SoulCalibur View Post
An 06 Crown Vic. :-P
- Alex B.
Ranger Up - Not everyone's war stories end in high school.
Out of the Thunderbird game for now.
alicks is offline
post #6 of 9 (permalink) Old 12-12-2008, 08:19 AM Thread Starter
I just wanted the diff... would it be alot of work to do? It's cold as crap outside and cant get any garage time until after Jan.
post #7 of 9 (permalink) Old 12-12-2008, 09:59 AM
Are you asking about the entire axle assembly, or just the differential?
if just the "diff", it doesn't say if it is trac-loc equipped or not, but:
open or trac-loc, the carrier is 31 spline
3.27 gears, aren't those what you already have?
If the entire axle, you know you have an IRS rear end, right? To install the axle would be a ton of work.
Bangster is offline
post #8 of 9 (permalink) Old 12-12-2008, 05:32 PM
Who is John Galt?
Moved to Differential forums
"Won't work, can't be done"
cougar_guy04 is offline
post #9 of 9 (permalink) Old 12-12-2008, 06:30 PM
if you want to use the whole assembly its alot of work that, well.... no one has tried (with the exception of backhalfed tubbed drag cars).
if you want the trac lok and gears alone its way too much money, and still will require work to use with the IRS.
