Any One Else Running a Welded Diff - TCCoA Forums
post #1 of 10 (permalink) Old 02-06-2009, 01:06 AM Thread Starter
Scottie6.0's Avatar
I Resently Welded my Open Diff so It would work as a solid Axle..
"I Drift My Birdie on Trackdays.."
n' I was just wundering if anyone else one here had and if they ever had any proplems w/ theres
Scottie6.0 is offline
post #2 of 10 (permalink) Old 02-06-2009, 02:52 AM
KorpseofDeath's Avatar
Send a message via AIM to KorpseofDeath
I was thinking of that, but I got a TL. I believe I heard that would be putting extreme pressure on the half-shafts unless you upgraded them. I could be wrong tho.
~1997 TBIRD 4.6L LX SPORT ~ Xenon Kit ~ 149K Miles ~ K&N ~ JMOD ~ Daily Driver
~1991 TBIRD 5.0L HO ~ Completely Stock ~
KorpseofDeath is offline
post #3 of 10 (permalink) Old 02-06-2009, 04:10 AM Thread Starter
Scottie6.0's Avatar
Commen Since would tell you ya.. But Its not all that bad rly..
What would you replace the half shaf w/ ??
post #4 of 10 (permalink) Old 02-06-2009, 07:50 AM
more than likley the fat shafts from early SC vehicles....its the passenger side axle that you want(2 of em of course).
post #5 of 10 (permalink) Old 02-06-2009, 07:55 AM
r429460's Avatar
I did that on my pinto back in 1980 when I had a 289 in it. Never had any problems with axles. I has an eight inch rear swapped in the car. Only difficulty was turning corners slowly, tires squealed a little.
Do a good weld, not just in spots.
r429460 is offline
post #6 of 10 (permalink) Old 02-06-2009, 02:33 PM
tbirdtess's Avatar
Only!
Hello
A welded dif is gennerally used in Racing. Streight line or Circle with stagger.
You will be putting unnessarry stress on axles & tires.
A trac-lok would be better for street use.
Thank You
Paul
Rainbow Sports
267 Oliver Street
North Tonawanda, NY 14120
716-692-7510
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #7 of 10 (permalink) Old 02-06-2009, 03:48 PM
They sell spools for 8.8s already no need to weld anything.
RICARDOA1 is offline
post #8 of 10 (permalink) Old 02-06-2009, 04:35 PM Thread Starter
Scottie6.0's Avatar
^ Spools have been known to strip on 240's so I went w/ a welded
Its Rly easy to do..
post #9 of 10 (permalink) Old 02-06-2009, 04:52 PM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Welding will save you about a hundred bucks.
tinman_72 is offline
post #10 of 10 (permalink) Old 02-06-2009, 08:27 PM Thread Starter
Scottie6.0's Avatar
I Love Mine..
