3.73 and then some - TCCoA Forums
post #1 of 8 (permalink) Old 04-18-2009, 12:57 PM Thread Starter
96tbirdboi's Avatar
3.73 and then some
im going to go with 3.73 gears i want to get a aluminum driveshaft or a mark 8 driveshaft kinda confused there, i here some people use the 99-01 cobra differential where could i find a 99-01 diferential if this fits on my thunderbird,then i believe i should get a trak-loc assembly advice is appreciate
1996 ford Thunderbird LX 4.6L 2V [email protected]
PI Swap(heads/intake)
Comp 262 cams
Sport springs
True dual exhaust(Magnaflow cats/Mufflers
Steeda UDPs
Trick flow tb/plenum
96tbirdboi is offline
post #2 of 8 (permalink) Old 04-18-2009, 01:15 PM
JR Tigerstar's Avatar
It will probably be easier to find a Mark VIII pumkin.
IIRC all Mark VIIIs had the aluminum differential housing.
JR Tigerstar is offline
post #3 of 8 (permalink) Old 04-18-2009, 01:27 PM Thread Starter
96tbirdboi's Avatar
who sells them and do they have trak-lok
Comp 262 cams
Sport springs
Steeda UDPs
post #4 of 8 (permalink) Old 04-18-2009, 01:35 PM
Mark VIII's were never trac-loc. Look for the cobra unit. the 93 (only) Mark VIII driveshaft is a one piece shaft. Other years are 2 piece and known for vibration. You can do a lot of shoping @ www.car-part.com
BYE2YOU
growing old is inevitable
growing up is optional
94 SC
05 PT Cruiser GT Turbo Convert
Ken Horner is offline
post #5 of 8 (permalink) Old 04-18-2009, 01:42 PM Thread Starter
96tbirdboi's Avatar
the scp aluminum driveshaft aint one piece??? is the mark 8 driveshaft aluminum??
Comp 262 cams
Sport springs
Steeda UDPs
post #6 of 8 (permalink) Old 04-18-2009, 01:57 PM Thread Starter
96tbirdboi's Avatar
got any other sites
Comp 262 cams
Sport springs
Steeda UDPs
post #7 of 8 (permalink) Old 04-18-2009, 02:03 PM
Ken is correct. No Mark VIIIs had trac-loc.
You can use a '99 Cobra differential.
It was the only year to use 28 spline.
Good luck finding one.
Empty 8.8 Aluminum Mark VIII Pumpkin
I recommend the after-market driveshaft over the '93 Mark VIII driveshaft.
I also recommend you replace your transmission mount with a soild rubber unit
and your differential bushings with some polyurethane bushings.
You will also need a new speedo gear (purple 21 tooth).
post #8 of 8 (permalink) Old 04-18-2009, 02:31 PM Thread Starter
96tbirdboi's Avatar
thanks alot but u can get a trak lok on scp i think for the mark 8 differential sry still trying learn about performance so im kinda new to some of this stuff
im going to go with the aftermarket driveshaft the 3.73 gears
try to find a mark 8 pumpkin andget a trak lok
should be a small amount of weight removal on my car to with the mark 8 pumpkin
i appreciate the advice thanks alot
Comp 262 cams
Sport springs
Steeda UDPs
